Zombie7.3's 12 Year No-Start Resto-Build
#31
Finally got it up there! Skid plate around the torque doubler (I think that's what it's called) got caught on the edge of the trailer and gave us all kinds of trouble.
Weird-*** breather tube (??) coming off a Tee from a line from the brake booster?
Mouse nest made out of reflective firewall insulation.
Worst body damage on the truck. Wyoming wind ripped the door out of the PO's hand.
Whelp, tomorrow we drive 200 miles across the state to bring it home. Sure hope the 3/4 ton Chevy can do it! I swear the last thing they did before parking it was take it mudding. Fortunately the father-in-law has a power washer and we got most of the mud from the undercarriage washed out. Also wrapped a bag around the alternator and power washed the engine bay.
Brakes still had pressure, which I'll take as a good sign. Wasn't able to get the TC into neutral, so I tried hooking up a jump pack to the battery to see if there was maybe a solenoid that kept the TC locked into 2H and 4H that might release with a little power. No luck with that, but all the lights lit up on the dash, so I'll take that as a good sign, too. Once I get it home I'll start a build thread, but don't expect any fancy mods. Aside from getting road worthy the only thing I'd really want is a visor and a bumper. We'll see though, lol.
#33
brake booster line could be couple things? maybe they had it rigged up for ether or to use an engine cleaner?......but hello....mcfly.... vacuum pump....I cant figure that one out.
That skid plate is the transfer case skid plate
Good luck with her!
remember, check the glow plugs with ohm meter, and fuel lift pump is mechanical. could save you alot of headache and endless cranking.
Good luck with her!
#34
The shift lever for the transfer case is probably stuck/corroded around the bolt that the lever pivots on. The bolt is steel, and the bracket is aluminum so the 2 different metals set up a chemical reaction when moisture and mud are introduced to them. Remove the pivot bolt and take it to a wire wheel and shine it up. Coat it with grease and reinstall.
#37
I'm not a welder yet, but plan to be before the summer is over. Hopefully there'll be a big deer killer on there before winter. Pics of the cholo bumper for the laughs?
#38
Ask and ye shall receive - https://www.ford-trucks.com/forums/1...co-a-poco.html Post 9
I hear MOVE? makes good DIY bumpers. Do the headlight relay harness upgrade. Jeff's Bronco Graveyard is cheapest place for it.
#39
#42
#43
#44
#45
Tanks look great, so does the fuel. I have ran worse. Drop and drain both to be safe, a couple hours will save your azz down the road on injectors, drain the bowl, change the filter, and check the FPR screen, Throw 5 gallons in it and go start it.
I bought a CCLB 350 with Dump bed for 1200$, sat 3 years, I put batteries in it and it fired up on the second revolution... I was a bit shocked. Not a hitch with the truck since outside of the blown trans right off the lot.
