Axle swap
Old May 1, 2019 | 04:32 PM
jcnorton's Avatar
jcnorton
how long is your driveshaft, mine is roughly 69.25 on same layout with 9.75, mine is a 5.0 4x4 so i'm not sure we have the same trans to make the comparison valid. you might do a search on an auto parts site to see if it calls for the same rear ujoint as that might need a different yoke on your shortened shaft. If your shaft needs to be shorter then that should be quite less than a new one?
Old May 1, 2019 | 05:49 PM
steve(ill)'s Avatar
steve(ill)
if your only moving it 1-2 times a year, why bother with the axle... the axle is NOT your problem. Going over the limit 500# will not hurt the axle. If your trailer has its own brakes, I would not bother with a 9.75 axle.
Old May 3, 2019 | 01:32 PM
Cekiert's Avatar
Cekiert
To be continued
I'm going to see if I can adjust the trailer some to assist in the payload. I saw something called haulgauge for 100$ that plugs into obd port. I might be able to make the factory setup work. I honestly don't have accurate wieghts on the trailer, sticker is worn off. Manufacturer isn't around anymore. It went to a scale before for a tax collector. And even then I got the tax collector to accept the scale weight minus door sticker on the truck. Which had 1000lbs in Aftermarket stuff.
With real accurate axle load data, I might be able to adjust the load and get it all good or maybe get creative and remove the tailgate to make up for payload. I saw data online from a sister model having a 1200lb pin wieght. But It's had a number of changes over the years. If I can't get it to a manageable number. I'll revisit this swap
Fire57
Oct 29, 2014 09:29 AM
Mike F250
Feb 6, 2012 04:50 PM
james.mcafee1
Mar 16, 2010 08:32 AM
gto66pont
Jun 13, 2005 05:05 PM
BlackSheep
Offroad & 4x4
Apr 24, 2000 08:08 PM
