Windshield Trim Removal
Old Oct 2, 2003 | 08:17 PM
MRStace84's Avatar
MRStace84
How do you remove the trim around the windshield? I have a trim removal tool that I got from Harbor Freight. I somehow managed to remove the side pieces, but I cannot for the life of me, get the bottom one off. There are 4 tools in the kit, and I have tried 3 of them from every angle that I can think of, and I still cannot get the molding to release.
Do you put the tool in from the window side or the cowl side? Do you hook the clip and pull, or push it up or down to release?
Thanks in advance.
Old Oct 4, 2003 | 12:49 PM
Jens's Avatar
Jens
Hi,
here is a pic.....
good luck
Jens
Old Oct 8, 2003 | 10:54 AM
akbg's Avatar
akbg
be carefull if you have not removed it yet, I just cracked my windshield taking out the lower chrome.
Old Oct 8, 2003 | 11:57 AM
MRStace84's Avatar
MRStace84
Got mine off. I think dumb luck mostly
Old Jan 16, 2004 | 05:10 PM
Bronco Billy's Avatar
Bronco Billy
The bottom clips are built a bit differently than the sides, and top.
The clip is a heafty tab, with a rectangular punch-out in it's middle. the removal technique is similar to the others - work from the glass side, and pull. BUT, you'll have to reach a bit higher up inside the trim (further from the glass) to be able to pull the required poundage to get these to release.
Instead of just holding a bit of chrome against the cowl, the chrome moulding it's self has a thick plastic tab, which doesn't slide out as easily. They hold tighter, due to the fact that this moulding actually holds the back side of the cowl to the truck...
Hope this rambling helps...
Bronco Billy
tonfro
Feb 12, 2015 04:17 PM
1990f150dude
Aug 5, 2012 11:45 AM
Kalve
18
Mar 28, 2011 11:55 PM
