TPMS Question
Old Apr 29, 2019 | 08:37 AM
JDJR59's Avatar
JDJR59
TPMS Question
I have a chance to purchase 4 OEM rims with sensors. My question is, After I buy and mount new tires will my truck see the sensors automatically or will I need to make an appointment with Ford service? I have a 2019 F250
Old Apr 29, 2019 | 09:17 AM
vavtx's Avatar
vavtx
My 20” takeoffs learned automatically on my 2017.
Old Apr 30, 2019 | 11:37 AM
62KR's Avatar
62KR
I will be installing my takeoffs within a week... I expect mine to work as well, and will report back if they don't...
Old Apr 30, 2019 | 12:56 PM
jlalanas's Avatar
jlalanas
I would think that you might have to run through the TPMS training process for the truck to acknowledge them. It's detailed in the owners manual.
Old Apr 30, 2019 | 01:06 PM
kongar's Avatar
kongar
I've googled this very same topic and can't seem to get a straight answer. There's learning new TPMS sensors, switching between sets of previously learned sensors, and then tire rotations - aka does the vehicle know which wheel is in which location. There seems to be no consensus, and parties on each side insist they are right. I'd love to find a single thread where everybody agrees on the one reality. (sometimes I wonder if trim level affects this, and that's the cause of the confusion).
Who knows...
Old Apr 30, 2019 | 01:15 PM
seville009's Avatar
seville009
I’ve purchased winter tire packages with tpms valves online and the vehicles (all Fords) for years have never had a problem sending them once I put them on.
worst case if your truck doesn’t recognize them is take them to a tire shop and have them use their tpms tool
Also make sure the batteries in your sensors are good before you get it all installed. They do go bad relatively quickly.
Old Apr 30, 2019 | 01:39 PM
jlalanas's Avatar
jlalanas
Who knows...
Yes, the vehicle know the pressure of each wheel once you go through the TPMS learning process. Basically you initiate the process with a sequence of ingition cycles (detailed in the owners manual) which puts the vehicle into TPMS learning mode. Then you go to the front left tire and let some air out of the tire until the horn sounds, then you move to the right front (do the same thing and wait for the horn), then the right rear, than left rear. Once you make your way around all four corners the process is complete. Alternatively, you can purhcase the TPMS tool on Amazon for $12-15. You basically do the same thing but instand of having to let air out o the tire you hold this little TPMS gadget near the valve stem and hit the button.
pgordon888's Avatar
pgordon888
For my '19 f350 I purchased brand new wheels and tires w/ new untrained Ford TPMS and had to run the ECU train procedure myself to train the new TPMS as they would not train automatically from driving.
The Super Duty ECU needed to be triggered for TPMS training using a very specific ignition key cycle I found here (hazard light method referenced in manual only works for tire rotation of previously paired TPMS) followed by TPMS "wake-up" activation with my TPMS handheld tool (air deflation should work too for Fords TPMS).
Or you could just go to the dealer or tire shop and pay the $100 charge to get it done.
Old Apr 30, 2019 | 05:43 PM
kongar's Avatar
kongar
See what mean? Handful of replies and already different answers in the same thread. I’ll do the thing and see if it happens by magic. If not, do the hazard light thing. If that doesn’t work, do the ignition key thing.
Old May 6, 2019 | 10:45 PM
62KR's Avatar
62KR
I put my takeoff wheels on today, and the truck immediately saw them. Went through a relearn to get them in the correct position. Basically no different than a tire rotation.
Old May 7, 2019 | 02:55 PM
HCSGuy's Avatar
HCSGuy
I bought a set of take off wheels/tires that had no TPMS sensors in them. Took them loose to Costco and paid them to put the sensors in. Took the loose tires home, put them on my truck, and it read them without me having to do anything.
fishforlife2007
18
Feb 15, 2015 02:31 PM
V1GiLaNtE
Jan 24, 2007 09:15 PM
