6.2L V8 Discuss the 6.2L V8
Little Maintenance
Old Apr 28, 2019 | 07:25 PM
irocdupi's Avatar
irocdupi
Little Maintenance
So today I decided to do a little maintenance to my truck. 2015 F250 35,300 miles 1970hr 532 idle hours. Its a snow plow truck in the winter and pulls my boat in the summer. Decided I would flush the coolant, change the serpentine belt. and all the plugs. Everything went fine besides one plug on the top of the motor. Bolt holding down the coil pack was corroded in, ended up snapping the bolt in the coil pack. Little work and some heat and we eventually got it out. One thing to be noticed, plugs on the bottom half of the motor should I say were double platinum motorcrafts. Top plugs were just platinum motorcrafts and definitely showed more signs of wear. Top plugs were very dry coming out. Most important thing I noticed was that all the lower bolts on my valve covers on both sides of the block were completely corroded away... Not even there anymore. I have one month left on the powertrain warranty im going to call ford and see what they have to say about it. Truck is meticulously maintained and washed. Very minimal rust on the truck at all. Just stumped to see the valve covers looking the way they do. Wondering what Ford is going to say about this?
Old Apr 29, 2019 | 06:54 AM
tjc transport's Avatar
tjc transport
i ain't rite
my bet is it was from salt spray getting into the engine bay and not washed off the engine.
i see it on a lot of plow trucks here in New Jersey.
Old Apr 29, 2019 | 02:21 PM
irocdupi's Avatar
irocdupi
Sad thing is that the truck and the motor are washed immediately after any snow event
Old Apr 29, 2019 | 03:23 PM
Squisher's Avatar
Squisher
Well something from winter/salt caused it. My 2011 has never been winter driven and it's spotless. Zero corrosion issues.
Old Apr 29, 2019 | 04:03 PM
irocdupi's Avatar
irocdupi
Obviously something caused it to rust, just amazing how there's no rust any where else and just so happens that those bolts completely deteriorated. Going to see what ford has to say before my powertrain is up.
Old Apr 29, 2019 | 04:31 PM
Squisher's Avatar
Squisher
I hope they might help you out but don't be surprised if they don't. Espescially on a plow truck. I commercial plow contracted for ten years and was always amazed at the damage it did to trucks. Specifically the front end/engine compartment. The blades kick up a lot of crap into that area.
Old Apr 30, 2019 | 08:32 AM
Chuck's First Ford's Avatar
Chuck's First Ford
washing does NOT remove all the salt... it sits and eats
50 years as a mechanic... Cleveland Ohio.... salt eats everything...
plow trucks are a Bit** to work on after 2 years... regardless of care.. or washing.
you truck is showing you just how hard plowing is on a truck
just a case in point.. Ford calls for first spark plug replacement at 90,000 miles
I moved to Texas 8 months ago. I retired.
Old Apr 30, 2019 | 04:00 PM
irocdupi's Avatar
irocdupi
Says plugs should be changed at 60k under severe duty. I wanted to change them a little early Incase it had the same problem as the 5.4s getting stuck in.
Old May 1, 2019 | 05:20 AM
Chuck's First Ford
you are correct..
my opinion.
snow plowing is very hard on trucks...engines, transmissions, suspensions, steering, Rust,
to the point... replacing cylinder heads...or rethreading spark plug holes... from spark plugs rusted SOLID to the heads... on 3-4 year old trucks.
Old May 2, 2019 | 02:37 PM
irocdupi's Avatar
irocdupi
Spoke with ford today, they are ordering two new valve covers for the truck.
Old May 3, 2019 | 12:20 PM
llmflyfisher's Avatar
llmflyfisher
I worked in Ohio for a couple years. Never seen more than a deep south TX winter. Those winters blew me away. Never again. Smart man moving away from winter. Now if we could just get the transplants to NOT vote like a bunch of communists and try to take our guns away would make up for them moving here.
Old May 3, 2019 | 11:56 PM
Squisher's Avatar
Squisher
Surprising to me, but good for you! Glad they're looking after you.
Old May 4, 2019 | 06:42 AM
irocdupi's Avatar
irocdupi
Ill take it, truck has until the end of the month before powertrain is up.
Old May 8, 2019 | 05:57 PM
screamineagle31's Avatar
screamineagle31
You got lucky! Kudos to your dealer, they could have easily said no. Glad it worked out for ya!
lawnspecialties
Feb 7, 2019 09:04 AM
xtal_01
Dec 10, 2015 05:58 AM
Electricredmetallic
Mar 15, 2014 10:55 AM
Cap'n Tea Bag
1997 - 2003 F150
Dec 29, 2009 08:07 PM
turn7
Modular V10 (6.8l)
Jul 27, 2009 11:21 AM
