Steering wheel controls acting up
Old Apr 26, 2019 | 11:17 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
My steering wheel media controls are acting up. They are all doing the wrong functions. For example volume up is changing the mode. I've heard this could happen on the previous gen trucks, is it also heard of in these trucks?
Is the fix just replacing the buttons?
Old Apr 26, 2019 | 12:14 PM
KJ Smith's Avatar
KJ Smith
My '13 had that issue.
Ended up being the clock spring.
Old Apr 27, 2019 | 05:34 AM
GABAR's Avatar
GABAR
[QUOTE=A/Ox4;18622394]My steering wheel media controls are acting up. They are all doing the wrong functions. For example volume up is changing the mode. I've heard this could happen on the previous gen trucks, is it also heard of in these trucks?
[/QUOTE
Have you tried going into the settings menu via the SYNC screen and doing a Master reset.
This might be an APIM problem.
Old Apr 27, 2019 | 07:08 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Yep. Didn't work. This problem is also intermittent.
Old Apr 27, 2019 | 08:22 AM
Grelda1975's Avatar
Grelda1975
The exact same thing happened in my truck. The dealer replaced the 4 buttons and everything has been good since.
Old Apr 29, 2019 | 04:08 PM
Rickyrobert's Avatar
Rickyrobert
That is one of the oddest things I've seen on one of these. I'm betting that replacing the buttons would fix it
Old Apr 30, 2019 | 05:51 PM
johnlastunas1995's Avatar
johnlastunas1995
It could be the same issue KJ had..
Old May 1, 2019 | 09:57 AM
alloro's Avatar
alloro
Ditto on the clockspring being the likely culprit.
Old May 1, 2019 | 11:43 AM
Grelda1975's Avatar
Grelda1975
Well after saying that replacing the buttons fixed the problem, just this morning the same weird things started happening. The dealer replaced the buttons a little over a month ago and all was good until this morning.
Old May 1, 2019 | 11:45 AM
Grelda1975's Avatar
Grelda1975
This might be a dumb question, but what's the clock spring?
Old May 1, 2019 | 06:46 PM
KJ Smith's Avatar
KJ Smith
I went through the same process.
Replaced the buttons (did that myself, easy enough).
Worked ok... then started acting up again.
Mine seemed to act up more the warmer it got outside.
Took it to the dealer and they replaced the clock spring.
That truck had an extended warranty.
A clock spring allows the steering wheel to turn without tearing up all the wiring.
https://www.bing.com/videos/search?q...2409&FORM=VIRE
Old May 4, 2019 | 03:58 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Thanks guys. Looks like the clock spring will probably be the culprit. What causes this? Worn insulation? Bad contacts?
Also, how difficult/easy is it to replace the clock spring? I watched part of that video in the previous post.
Old May 4, 2019 | 05:29 PM
KJ Smith's Avatar
KJ Smith
Just another faulty part that needs improvement.
Probably a lower failure rate that is within Ford's tolerance.
On my '13, you have to pull the airbag to change the buttons.
I did that myself.
When that did not cure the issue, I was advised that the problem was likely in the radio.
I took it to the dealer because I had an ESP on that truck.
They correctly identified it as the clock spring.
Air bag and steering wheel have to come off.
Only you can decide if your comfortable removing the air bag.
Old May 5, 2019 | 07:05 PM
alloro's Avatar
alloro
Years ago when it was just the horn circuit passing through the clockspring there was a contact. Now with all of the cruise and radio controls there's actually a ribbon cable wrapped inside the clockspring assembly. Over the years as the steering wheel gets turned back and forth the flexing of this ribbon cable takes it's toll and conductors start to break internally.
Old May 5, 2019 | 07:42 PM
SKAGGS77's Avatar
SKAGGS77
I don't care for the "lower failure rate" argument with any manufacturer. My '05 Explorer had this problem, my '05 F150 FX4 had this problem, and my assumption is that my '18 F150 will also have this problem. I hope that it's something they will address, quickly.
z 97ford1
1997 - 2003 F150
Oct 2, 2021 12:13 AM
soupy1957
2009 - 2014 F150
25
Dec 15, 2012 01:06 PM
BlackFX4Screw
2004 - 2008 F150
Jul 21, 2007 09:30 PM
JWest
Appearance & Dress-Up
Jun 14, 2007 02:42 PM
m@m
2004 - 2008 F150
Apr 29, 2007 07:08 AM
