Sponsored by: Real Truck
Brakes Dragging
Old Apr 25, 2019 | 03:48 PM
jtwat's Avatar
jtwat
Brakes Dragging
2008 F350 SRW 6.4 Diesel.
The brake hydro-boost was leaking fluid inside the cab due to a bad seal. I replaced the hydro-boost with a Reman. unit. Replace the master cyl. also with a new one.
Brakes worked fine for about a week but now after several brake applications, the brakes are dragging to the extent that they getting hot.
I broke the lines loose at the master cyl and pressurized fluid squirted out. After tightening lines, brakes work normal for a while but then start to drag again and I have to stop to release the pressure again.
Dd I get a bad hydro-boost or something else?
Thanks for the elp.
1968F100ShortBed
Sep 12, 2010 10:26 AM
wmiller
Apr 30, 2008 01:39 PM
petelynch
Sep 28, 2007 05:26 PM
merv1
Oct 26, 2003 08:52 PM
paulieman
Dec 10, 2002 04:11 PM
