Brake Adjustment
Old Apr 24, 2019 | 02:10 PM
Daggers's Avatar
Daggers
Brake Adjustment
Hi All,
1946 1/2 ton Jailbar
After over 2 years work I am almost on the road, just one problem, brakes.
I have a standard fully rebuilt drum brake system with 1/4” pipes. Dual reservoir master cylinder fitted with a conversion plate, sold as a kit by mid west ford and the original pedal cluster.
After adjustment I end up with a very long pedal movement, I asked the kit supplier if residual valves were required on the lines but they were unsure.
The master cylinder is 1” bore and looks like a drum/drum mustang. I think the original master cylinder was 1 1/16” bore, so that could be the reason for the longer movement.
Has anyone used a similar master cylinder conversion? Is there a larger bore master cylinder that fits the same conversion plate?
Any advice, suggestions welcome.
Old Apr 25, 2019 | 09:25 AM
51504BAT's Avatar
51504BAT
Can't help you on the brake problem but I'd ask over on the HAMB and Ford Barn as well. Lots of discussion over on those boards about m/c issues in general and old Ford systems in particular. JMO
Old Apr 26, 2019 | 03:47 AM
Daggers's Avatar
Daggers
Will pay these forums a visit
thanks
Daggers
Old Apr 26, 2019 | 07:55 AM
51504BAT's Avatar
51504BAT
thanks
Daggers
One word of advice, if you join the Hamb (no charge) so you can post, make sure you do an intro before posting. That way you won't start out on a bad note. The Hamb is for traditional pre '65 vehicles so never use the word rat rod or refer to EFI or other modern stuff. Still a lot of good info there. You can have EFI or other modern stuff, just don't mention it in your posting.
Old Apr 26, 2019 | 12:25 PM
Daggers's Avatar
Daggers
Thanks for the advice, would not like to upset anyone....
Old Apr 26, 2019 | 10:41 PM
Steve Christensen's Avatar
Steve Christensen
G'day Daggers, on my '42 1 1/2 ton I used a dual circuit master cylinder off a 70s F250 , it has the same bore size as the original ... 1 1/4'' . I also fitted 10lb residual valves, one for the front
circuit, one for the rear . Some master cylinders have residual valves in the ports, the F250 master cylinder I used didn't. Brake circuit diagrams show residual valves in line, 10lb for drums,
2lb for discs. My brake pedal pedal travel is about 1''. Maybe the smaller bore in your master is enough to upset the system by not displacing enough fluid.
Cheers, Steve.
Old Apr 27, 2019 | 04:51 AM
Daggers's Avatar
Daggers
Hi Steve,
I think you are correct, I would guess that the swept fluid volume is less therefore the pedal movement has increased.
My pedal travel is over 2”, for my non power dual drum system.
I will now, armed with your advice, start looking master cylinders from later ford pickups.
I think the problem will be that most will use front discs and possibly power systems.
Will post results later, thanks for the reply, it really is appreciated.
All the best
Daggers
Old Apr 27, 2019 | 06:41 PM
Steve Christensen
G'day, I have a reprint of the original Ford shop manual, now it looks like the supplier has supplied a master cylinder for an F1 , your truck isn't an F1. You have to match the master cylinder
to the wheel cylinders, hopefully the charts I'll attach are readable.
Cheers, Steve.
Old Apr 27, 2019 | 07:06 PM
Steve Christensen
Ignore what I said about the F1........ I read the wrong column ......... anyhow, a brake shop should be able to help you out, that's what I did.
Old Apr 27, 2019 | 07:15 PM
Steve Christensen
One more thing, here's a photo of my set up.
Regards.
Old Apr 30, 2019 | 06:00 AM
Daggers's Avatar
Daggers
Hi Steve,
thanks for the info, I compared the above with the data in my handbook and my slave cylinders seem to total more than the above. So me using a smaller master cylinder bore cant help the pedal travel.
Today I spoke to a experienced car restorer and he advised me to look closely at all the elements in the system closely before changing the master cylinder. In his experience of 1940’s ford braking systems, which is considerable, 90% of brake problems come down to out of spec components and bad adjustment.
So I am taking each corner in turn checking drum diameter, ovality, cylinder action etc.
He also advised to isolate the front and back systems and confirm that the pedal action is equal to both.
Also taking much more care in adjustment.
Not too sure if this will help, but I will give it a try as I am desperate to get on the road after over 2 years work.
Daggers
Old May 1, 2019 | 05:43 AM
bernette's Avatar
bernette
hi guys ! last weekend i was bleeding my brakes on my 42. i have a original style master cylinder, which i installed in 2014 and it was working the rear brakes only. i add front brakes and hydro boost this winter. my old but new mastercylinder started leaking at rod. just saying new stuff now a days is not always good !
Old May 1, 2019 | 11:38 AM
Daggers's Avatar
Daggers
I too have had a couple of issues over the last two years with new parts failing or just not fitting correctly.
Just spent the last couple of days checking all parts of the braking system.
Checked the drums and found a problem on the rears.
Fronts O/S+52thou over stock, ovality ok, parallel across contact faces ok.
Fronts N/S+52thou over stock, ovality ok, parallel across contact faces ok.
Rear O/S +152thou over stock, ovality poor, parallel across contact faces poor.
Rear N/S +85thou over stock, ovality poor, parallel across contact faces poor.
Also found one of my new rear brake cables has a badly formed return spring, and was jamming the inner cable.
New rear drums on order, takes a couple of weeks to ship over to UK.
Corrected the cable with the aid of a dremel and grinding stone.
Hope this helps with the adjustment, we will see.
Daggers
Old May 8, 2019 | 01:54 PM
paul.table's Avatar
paul.table
Would it not be possible to alter the fulcrum point of the pedal/ pushrod to attain less pedal travel? Good luck
Old May 8, 2019 | 02:53 PM
Daggers's Avatar
Daggers
Hi Paul
that something I am looking at as the original pedal arm has two sets of holes at the master cylinder end. I am at the moment using the set that is closest to the pivot thus the shortest travel. Am going to move the master cylinder rod to the other set giving longer travel.
At the moment I cant test this as brakes are disassembled awaiting new set of brake drums.
I have a couple of repairs to do on the rear wings so its I'm happy to wait until I get the new drums. Cant believe that I removed the rear wings quickly, all nuts came off easily and no rust on either wing or bed.
pagoda69
Jun 28, 2019 07:22 AM
clr0gers
1947 and Older Ford Trucks
Jul 7, 2014 08:26 AM
JCastellaw
1966 - 1977 Early Broncos
Oct 4, 2011 07:20 AM
58f100rat
Aug 21, 2008 07:48 PM
TryMe
Dec 7, 2006 08:01 PM
