Engine swap
Old Apr 23, 2019 | 02:14 PM
Tony Watkins's Avatar
Tony Watkins
Engine swap
I have a 2002 vin e 4.0 sport trac 4wd and my donor motor is a 2001 ford ranger 4.0 4wd vin e, will these plug and play or how can I find out, everything looks like same. Any help is appreciated.
Old Apr 23, 2019 | 04:19 PM
85e150's Avatar
85e150
Welcome to FTE!
'01 to '02 and it looks the same--you are probably good.
Generally you strip to motors to the bare long block. You install all the recipient electronics, intake, exhaust etc on the new motor. In this case, if it's the same stuff, you have a step or two saved.
BUT
Are these SOHC motors?
Old Apr 23, 2019 | 04:45 PM
Tony Watkins
Yes both are sohc
Yes both are sohc, I know you can strip down to the long blocks and swap intake and etc but that is what I'm trying to avoid because it costs a lot more since I am paying a mechanic if he has to switch all that, I originally thought any 4.0 Vin E 4wd motor would work but some have the oil refill on drivers side and others that year are on the
passengers side so anybody's input is helpful cause trying to figure it out before I go buy the motor and the ranger engine has been the best deal I could find so far from a private party.
Originally Posted by 85e150six4mtod
Welcome to FTE!
BUT
Old Apr 23, 2019 | 05:28 PM
85e150's Avatar
85e150
IIRC 4x4 motors had balance shafts, not sure that changes anything.
Beware those motors should have the chain tensioners and guides replaced before you install it. (passenger side requires engine removal to service) You might also double check the condition of the chains, all 3 or 4 of them. (Crank to jack shaft, crank to balancer, jack shaft to driver cam, front of engine, jack shaft to passenger cam, rear of motor)
IF the intakes look the same, no need to change. The idea is to have the recipient vehicle's computer and wiring harness marry up to the new motor.
Stay tuned, you might get more replies.
Old May 30, 2019 | 10:07 PM
Mike Shannon's Avatar
Mike Shannon
It should work one big hurdle was the split in 2000. 01 to 02 will work I have a 01 sport trac and a 02 sport with the original engine from the 01. (this engine had a guide on the left bank break engine luckily never jumped time engine came with it) I did do research on cross refrence between 01 and 02 and they interchange. I would imagine the ranger will be similar. may have to swap the intake. I do agree with 85e150 spend the cash and put chains in it while its out it has to be out to do the right bank chain anyways I would only use a well known brand for the timing set. the timing tool is available from OTC.
team key largo
Feb 8, 2016 06:54 PM
BTFD29
1983 - 2012 Ranger & B-Series
Oct 14, 2014 06:33 AM
ghanson
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Nov 29, 2011 01:16 AM
zems
Dec 12, 2005 02:36 PM
fastmov4
Mar 15, 2002 12:37 PM
