Coolant Temp vs EOT from OBD2?
Old Apr 22, 2019 | 12:51 PM
psdowner's Avatar
psdowner
Looking to check the delta between the two temps to see if the oil cooler needs cleaning or replacing.
Can this info be read from he OBD2 port (which did not work with my scanner) or is something like the ScanGuage II needed?
Thanks
Old Apr 22, 2019 | 01:01 PM
Ford.Dude's Avatar
Ford.Dude
Not sure why your scanner wouldn't at least see those temps. But yes, I think the only way to see the true temp would have to be through the OBD2.
Old Apr 22, 2019 | 01:41 PM
diesel_dan's Avatar
diesel_dan
If you have an android smart phone you can download Torque (or for $5 the Pro version) or Forscan (which I think will run on IOS as well as windows), and buy an inexpensive bluetooth OBDII module, and you'll gain access to a lot more data than just those temps...
Old Apr 22, 2019 | 02:02 PM
psdowner's Avatar
psdowner
I'm not sure why the Live Data is so limited. I'm using an Innova 3130 OBD2 scanner, but may have to get something else.
Old Apr 22, 2019 | 06:48 PM
coolfeet's Avatar
coolfeet
I use the ScanGuage 2 and prefer the convenience of having the gauge always reading my important parameters.
Old Apr 23, 2019 | 01:22 AM
quietman's Avatar
quietman
If you're like me and have a drawer full of old phones, you can do this.
Jtpadilla1030
Jan 16, 2018 09:51 PM
JamesMcMn
Oct 17, 2016 10:47 PM
danocross
Feb 5, 2014 07:03 PM
tpull3
Jan 1, 2012 06:05 PM
Acftmaintainer
May 3, 2011 10:38 AM
