1978 - 1996 Big Bronco
Bronco stalls in reverse
Old Oct 2, 2003 | 03:35 PM
bigbluebronco43's Avatar
bigbluebronco43
Hey guys when i'm in reverse in my truck and i go to stop and put it into drive the RPM's drop real low like its going to stall. When i do the same thing and turn the steering wheel it usually does stall. I'm not sure if this has anything to do with it but when you shut my truck off somewhere in the engine compartment there is a woosh type sound, like if you were too blow air out of something. Any help is appreciated, i'm thinking its a vacum line of some sort but have no idea where it is.
Old Oct 2, 2003 | 03:57 PM
subdude's Avatar
subdude
My 89 was doing the same thing without "woosh type sound". It also stalled when shifted into park and wouldn't stay running with the remote start. I cleaned the K&N, changed my fuel filter, and used some injector cleaner. That solved it all for me. It still idles a little rough for a few seconds with the remote start, but it seems better everyday.
Old Oct 3, 2003 | 10:12 AM
bigbluebronco43
I'm not sure if this helps, but when you have the heat on it smells like its blowing some of the exhaust through the vents. I really want to find out what this is, please help!
motoxxman
17
Sep 30, 2016 11:48 AM
Jonathan Stone
Apr 28, 2016 07:41 AM
chadcam84
Oct 15, 2015 11:15 AM
josephk12
Jul 25, 2015 08:39 PM
David26
Nov 26, 2004 11:31 PM
