Metal prep
Old Apr 20, 2019 | 10:07 AM
fordboy300's Avatar
fordboy300
Metal prep
Hey guys! I haven't posted in a while. But im getting ready grind down some rust spot I have on my floor boards. I'm gonna treat them with por15 and was wondering what could I prep the metal with.
Any suggestions would be great!
Old Apr 20, 2019 | 10:31 AM
dustyroad's Avatar
dustyroad
If you don't want to mess around, use straight muriatic acid, it will dissolve the rust and give nice shiny metal.
You have about 24 hours before it flash rusts again.
you also can use phosphoric acid which will convert any rust left over to iron oxide.
Use a respirator/safety glasses and chemical resistant rubber gloves and rinse well..
If it's pitted pretty well and grinding/sanding will take too much material off to get to those areas, use a combination.
Muriatic >rinse> phosphoric >rinse >seal
I used muriatic on my drivers doors last summer and rattle can'd it. It still looks good enough.
I used a chemical resistant spray bottle, sprayed the acid on, rinsed it with plenty of water, let it dry and rattled primer/paint on it.
I don't recommend windy days if outside and not in any part of a driveway you care about. It will eat pavement and probably etch concrete.
Since it's floorboards you most likely won't have to worry about that though, as you'll be sponging up the excess.
Keep the other door open to allow airflow thru even though you'll be wearing a respirator you don't want the acid fumes hanging around.
Old Apr 21, 2019 | 02:21 AM
dagwood57107's Avatar
dagwood57107
I just did my new 38 gallon rear tank with Por15. I used
Por15 Cleaner Degreaser Por15 Cleaner Degreaser
as well as
Por15 Metal Prep. Por15 Metal Prep.
(links to amazon) I'm sure other stuff will work, but i'm lazy and prefer to keep the same brand throughout a project instead of researching to see what works and what doesnt work. I honestly dont know if there are some products out there that dont react or work well together. I will say the Por15 cleaner stuff and prep worked perfectly.
Old Apr 21, 2019 | 03:57 AM
Rembrant's Avatar
Rembrant
I've been using Ospho lately and have been pretty happy with it.
Ospho Rust Treatment - Since 1947
Once it dries I just over it with a rust paint.
Old Apr 21, 2019 | 07:18 PM
fordboy300's Avatar
fordboy300
UPDATE guys I just finished up my little project yesterday. I used rubbing alcohol on a shop towel and waiting till it dried man the por15 rust preventive is great stuff!
Old Apr 26, 2019 | 08:41 AM
dagwood57107
On my research the POR15 required metal etching to adhere to clean metal surfaces - could you post an update on how well it holds up at a later date?
jvmcc
Sep 12, 2013 10:57 PM
sconut1
Paint & Bodywork
Sep 1, 2008 07:34 PM
FordF350Baby
Paint & Bodywork
Apr 2, 2007 09:55 AM
Jeff55F100
Paint & Bodywork
Aug 13, 2005 04:47 PM
sancochojoe
Mar 22, 2005 05:07 PM
