Stabilizer cylinder
Old Apr 20, 2019 | 02:18 AM
Budro574's Avatar
Budro574
Stabilizer cylinder
Anybody ran a stabilizer set up on their 2wd? If I hit a bun at 55 mph, the truck can get a bit hairy. Was wondering what I could for now to tighten it up. Next year I’m installing an IFS, so just need it to hang tight until then.
Old Apr 20, 2019 | 06:02 AM
Walston's Avatar
Walston
Yes I installed a stabilizer on mine. Works good, highly recommend it.
Old Apr 20, 2019 | 10:35 AM
1960fordf350's Avatar
1960fordf350
A bit hairy? In what way? Side to side, up/down? You don't get it at lower speeds? There's a lot of little things that can effect ride. Weak springs, bad shocks, bad tires and tire pressure. Bad kingpins, wheel bearings not tight enough, loose gearbox, bad draglink or tie-rod ends. Anything I missed?
Old Apr 22, 2019 | 10:20 AM
hiball3985's Avatar
hiball3985
Spring and shackle bushings
61 uni
Sep 30, 2012 01:19 PM
jc8825
Dec 16, 2010 09:39 PM
Stangrcr1
Aug 28, 2010 09:41 PM
Breech
Dec 12, 2007 11:51 AM
mybackiskillingme
May 28, 2001 07:55 AM
