brake lights
Old Apr 20, 2019 | 12:01 AM
saauvenshine's Avatar
saauvenshine
brake lights
1954 ford truck rewired with original wring harness. Everything is working but can not get brake lights to work. Have a new stock mastercylinder and stop light switch and even bought a low pressure switch and still no brake light. One wire is hot that goes to stop light switch at all time as it should be and tried with both leads pulled off pressure switch to use a jumper wire on both leads and still nothing. Been trying everything i can think of but no luck. Everything else is working headlights,park lights etc. just cant get brake lights to come on. Any thoughts would be deeply appreciated.
Old Apr 20, 2019 | 05:27 AM
JimG1098's Avatar
JimG1098
1. is you brake lights double filament or single filament.
2. At brake light, check for a good ground in the casing.
3. Can you light the the bulb at the casing by putting battery to it.
4. have you checked the bulb it self.
5. Have you checked continuity from stop light switch to bulb socket
Old Apr 20, 2019 | 07:29 AM
fordf348's Avatar
fordf348
If everything Jim has mentioned checks out make sure the 2 contacts on the bulbs make contact with the contacts in the light housing
Old Apr 20, 2019 | 09:30 PM
mtflat's Avatar
mtflat
Add a ground wire from the light housing (passenger side) to the frame.
saauvenshine
Feb 18, 2019 08:19 PM
DGMFORD
Sep 22, 2013 09:07 PM
usmc79ford
21
May 14, 2011 04:07 PM
Iraqveteran
Nov 3, 2009 10:36 AM
48fordf3
Apr 15, 2006 07:53 AM
