starting problems with 4.0L
Old Oct 2, 2003 | 01:58 PM
MeatGolem's Avatar
MeatGolem
I have a 90 ford ranger with a 4.0L.The truck has 2 problems,1st one is the truck has no power-the battery tests fine and I have replaced the starter relay,when I turned the key it has power but when I tried to start the truck it goes dead. The 2nd problem I have has existed before the 1st prob, I would have to turn the ignition key back and forth several times to get the truck to start up( it would turnover,catch for a second then die,it sometimes took me up to 20 minutes of switching the key back and forth to get it started) Can anyone give me a clue as to what could be causing either problem?
Old Oct 2, 2003 | 05:05 PM
mrshorty's Avatar
mrshorty
The first problem sounds exactly what mine do when there is a loose connection in the battery cables, or the battery cables themselves are corroded out.
The 2nd problem sounds like a fuel delivery issue. Check the fuel pressure and go from there.
Old Oct 6, 2003 | 07:27 PM
al125's Avatar
al125
I had a 1998 ford ranger /4.0 that lacked power. Replace the fuel and regulater,problem solved
