Auto vs. Locked
Old Apr 18, 2019 | 09:47 AM
BULLSEYEGUY's Avatar
BULLSEYEGUY
Trailering
Auto vs. Locked
OK. Here is kind of a dumb question. What is up with the "Auto" vs. "Locked" hubs on my '19 F-250? Do I need to run them in lock if I plan on using 4x4, or not? I am assuming that if they are in "Automatic" mode, the rear wheels will have to spin before the fronts engage, right?
Just bought the truck, and nothing but dry pavement for miles so I can't really play with it yet....but I want to know what works best. If I've got to drive in something where I know I'll need 4 wheel drive, I should go ahead and lock them out, right?
(I have gotten used to not having hub locks on my F-150, but I am good with manually locking them!)
Thanks!
The "new" guy. (eyeroll)
Old Apr 18, 2019 | 10:06 AM
350LTD's Avatar
350LTD
Leave it on auto. The button on your dash will lock the hubs. The locked setting on the hub is more of a back-up in case the vacuum line doesn’t work in auto.
Old Apr 18, 2019 | 10:11 AM
mhoefer's Avatar
mhoefer
The manual states locking hubs is recommended for 4 Low, and it’s a backup to the hubs if the vacuum engagement isn’t working so you still have 4*4. I have yet to manually lock my hubs, but I do regularly use them just to ensure they are functioning when I need them. I use 4*4 a lot all winter and do some off-road as well.
Old Apr 18, 2019 | 10:38 AM
Clubwagon's Avatar
Clubwagon
In auto, they are locked when selecting 4wd with the **** on the dash. The actuator is vacuum operated. And as stated above; there as a backup in case the vacuum actuators fail.
Operation is pretty seamless to the driver. Left in auto; simply turn the **** and wait for the "shift in process" notice to go out and the 4wd light come on. Reverse the process to switch back to 2wd.
I use 4wd on occasion; getting out of my driveway in the snow, climbing the hill that is the entrance to our development when towing in the rain. In 2wd i'll spin the rear tires on the polished asphalt. I really don't go offroad with it.
I do cycle the hubs occasionally, when I service or wash the truck, to keep them freed up. They can get stuck from lack of use.
Old Apr 18, 2019 | 10:43 AM
nrimshaw's Avatar
nrimshaw
I had read that it takes a 1/4 turn to get the auto locks to fully engage. If your stuck and cant get that 1/4 turn, then manually lock
Old Apr 18, 2019 | 10:53 AM
harmanrk's Avatar
harmanrk
I'm not sure why you would hear that. When the hub is locked, either manually or via the vacuum system, the splines on the axle will either engage with the splines on the hub, or they will not based on how things line up. As either the tire rotates, or the axle rotates, the splines will quickly line up and engage. It will be a lot less than a quarter turn (there are more than 4 splines), and it does not matter if the tire is turning, or the axle relative to each other.
Old Apr 18, 2019 | 11:24 AM
seville009's Avatar
seville009
One of many threads.....
https://www.ford-trucks.com/forums/1...-the-diff.html
Old Apr 18, 2019 | 11:48 AM
67L48's Avatar
67L48
Perfectly stated. As with most functions, it’s covered in the manual. Vehicle manuals are really a great resource.
Old Apr 18, 2019 | 11:51 AM
smokewagun's Avatar
smokewagun
This was the case back in the day when ford had ONLY automatic hubs without the twist dial. Hubs unlocked every time you went out of 4WD by driving a minimum of ten feet in the OPPOSITE direction you were going when the hubs were locked. Think back to the late 89’s and early 90’s.
BCfordman38
Apr 1, 2015 06:50 PM
terry_opie
Modular V10 (6.8l)
Jan 9, 2011 01:31 PM
Tangmus
Offroad & 4x4
Feb 23, 2009 09:39 AM
seldomseensmith
Dec 23, 2008 02:17 PM
wreakhavoc
Apr 23, 2007 06:06 PM
