I've had my Excursion for about 8 months and just discovered the 4WD is not engaging. I was in mud yesterday with the rear tires spinning so I switched to 4WD and heard the sound like it was engaging but then the rear wheels were still spinning but not the front. What is going on here?
Engage the 4wd off road. Turn on your a/c. If the air blows out of the defroster vs. the dash vents you have a vacuum leak. I found my leak on a $4.00 vacuum hose cracked going to the wheel. (I assume you have the ASOF) system with auto hubs. Jim
Did you rotate the hubs to lock and then try it? I converted mine back to auto/lock hubs after a 5 year stint with free/lock hubs. Took a bit of work to get the auto system working but it still is not 100%. I am losing vaccuum in the hub itself. I put new hubs and o rings on but still leaking somewhere in there.
It could be the actuator. Mine went in the first 15K miles of owning my truck. This past winter I am not sure what is wrong but once again no 4x4 using the switch. I can lock the hubs from the outside and rip through everything then. I only use 4x4 when offroading anyway and I would not trust the switch . It would suck to be out and about in the mud and then the switch doesn;t work. Then Iwould have to get out and lock the hubs manually and get my feet convered in mud.
No, I have not tried anything else. If you rotate the hubs manually then how would you determine if you were in 4-high or 4-low?
I don't know what ASOF means but it is the dial on the dashboard 2WD, 4WD high, and 4WD low. (2000 V-10)
If it was a bad actuator would you still hear the sound down there when you switch the dial?
If ASOF is Automatic shift on the fly,, which you have by your selector switch.
If you select 4wd HI or Low you might hear the electronic shift, but if your vacuum lines to the wheel hubs are damaged your hubs won't engage. If you select manual on the hubs and have 4wd you probably have a vacuum leak. There is a line from the chassy to the wheel that can easily break and prevent the 4wd from working. This is why I suggest to turn your a/c on and select 4wd. If there is a vacuum leak your a/c will only blow out of the defoger and not the dash vents. A quick easy check to see if you have a vacuum problem. So summary,, if you do the a/c check and don't have 4wd,, go outside and select manual on the hubs,, should be a clockwise turn about 60 degrees on the selector, if you have 4wd then you just have a vacuum leak which should be an easy cheap fix. Jim
I did as you said and the AC is blowing through the dash vents just like it should be, not through the defroster so it probably isn't a broken vacuum line, right? If you turn the hubs manually and are not in mud (or somewhere that the rear wheels would spin) how do you tell if the front wheels are operating?
Is there a way to test the actuator? This is especially a mystery to me because when I bought the truck it had 150,000 miles but everything on it looked and worked good as new. This was the first time I attempted 4WD.
you might select 4wd then pull the vac hose at the wheel to see if there is a vacuum. Key must be on. If there is no vacuum or weak you might have a vacuum leak. After doing this since you probably have the wheels jacked up, switch the hubs to manual and see if they lock up. If your wheels lock up to the differential in manual then you have a vacuum leak in a hub. Could be defective hub diaphragm.
IF turning the wheels in park lock the system up then the system is in 4wd and locked up through the transfer case. If the wheels are locked and the drive shaft to the transfer case turns but freely and the truck is in park,, then look at the actuator. They can be found on ebay pretty reasonable.
Note,, to get 4wd Low you must be in neutral foot on brake. Jim
I think it's working. (I didn't realize you had to be in neutral to shift into 4WD low and the vehicle needs to be in motion to shift into 4WD high. Yes, I should have read the owner's manual before wasting y'all's time here.) When I was in the mud the other day the vehicle was stopped when I switched into 4WD high and in park when I switched to 4WD low. I just went out and switched into 4WD low in neutral w/brake on and I heard it "clunk" and when I pulled out of the driveway I could tell it was a lot different than normal- nearly stopped dead when I let off on the gas so I believe everything is ok.
Thanks to all who replied and please excuse my ignorance!
ok after reading all of this, i now have a question on the system. my 4wd will lock up and the front wheels will drive the truck. but about 2 weeks ago, i went to pull into the driveway, and i heard what sounded like a bad u-joint in the front stub shaft. the switch is in 2wd, the hubs are in the free position. when i rotated the wheel, i noticed that the front axle would turn too. it did it on both wheels. it will not make the sound in reverse. and its only when i have the wheel turned all the way. i was thinking it was bad hubs. i checked and the u-joints are only $30/pair. any suggestions?? thanks...
