7.3 smoking
Old Apr 15, 2019 | 07:14 PM
pgg00's Avatar
pgg00
7.3 smoking
One of my 73s started smoking. There will be smoke at idle and when shifting. Nothing under load. If i rev without being under load it smokes as well. It appears to have a slight blue tinge when shifting. At idle when outside it has more of a diesel smell now. Any thoughts on the cause and a cure?
Old Apr 16, 2019 | 07:17 AM
Olds64's Avatar
Olds64
Bluish smoke can indicate its burning oil. Do you have to add oil regularly?
Old Apr 16, 2019 | 12:25 PM
pgg00's Avatar
pgg00
I usually have to add a quart once between every oil change.
Old Apr 16, 2019 | 12:39 PM
Olds64's Avatar
Olds64
1 quart between oil changes is about 10x slower than my 86 burns/leaks oil.
Since the truck idles fine in the video I would be hesitant to call it air intrusion. You could drop the fuel filter when the truck is cold and look at the level of the fuel. If it's low that is due to air intrusion. Is it difficult to start? If you drop the fuel filter replace/empty it and fill it with ATF. You can then run it for a few minutes and shut if off over night. The ATF acts as a detergent and will clean out your IP and injectors.
Old Apr 16, 2019 | 12:43 PM
pgg00's Avatar
pgg00
I need to try that or diesel kleene. My thought was maybe injectors starting to go and not getting good combustion because of it.
Old Apr 16, 2019 | 03:54 PM
tjc transport's Avatar
tjc transport
i ain't rite
my bet is a sticking injector dumping too much fuel.
Old Apr 18, 2019 | 07:25 PM
pgg00's Avatar
pgg00
I put some atf in the filter and let it run for a few minutes (no smoke at all then except for start up). I'll let it sit for a few days now and see.
Old Apr 19, 2019 | 06:41 AM
Olds64's Avatar
Olds64
OHHH YEAHHH!
Melendez7.3
16
Oct 23, 2015 12:26 PM
jgrohs54
Sep 1, 2015 07:13 PM
bootsgmc
Jun 21, 2008 08:45 PM
IHdieselfan
21
Apr 4, 2006 11:03 PM
Dholt
Sep 24, 2003 02:43 AM
