Relay identification
Old Apr 8, 2019 | 08:19 PM
HP8177's Avatar
HP8177
I’m having some electrical issues after an engine swap. 1987 f350 6.9. I found this relay socket on the drivers side engine bay without the relay on it. Does anyone know what components this is for?
Old Apr 17, 2019 | 04:40 PM
Perk85F250's Avatar
Perk85F250
No idea what it's for. Put a jumper wire across the two large terminals and see what happens
Old Apr 18, 2019 | 09:43 PM
HP8177's Avatar
HP8177
Yeah, I ended up removing the relay and splicing the hot to hot and grounding the ground. It fixed my tail light and marker light problem but I still have the problem of both tail signal lights flashing at the same time regardless of if I hit the left or right signal. My fuel gauge needle also moves to full and pegs out whenever I hit the brake pedal.
Old Apr 19, 2019 | 11:04 AM
Perk85F250's Avatar
Perk85F250
Sounds like a ground issue with your stop/turn lights. The relay may have been a towing package for trailer tail lights. Maybe someone here can get you a circuit diagram.
R&T Babich
Feb 21, 2017 07:10 PM
BigBlueX
May 25, 2015 01:25 PM
DPDISXR4Ti
Apr 21, 2012 07:27 AM
Bernie Lomax
Electrical Systems/Wiring
Nov 25, 2008 06:54 PM
ojesuscares
1997 - 2003 F150
Jul 27, 2004 12:06 AM
