Weight of longbed Styleside
According to this its about 3325lbs
good info: https://www.blueovaltech.com/history...ord-trucks.php
I've seen others do it with an engine lift and even removing rear wheels and blocking it up, then rolling truck out from under. Either way, rexblue has options with or without help.
Ha ha, yup, make em work, they'll be the better for it. My kids are long gone. Good to know its manageable, I lifted one end and it was pretty heavy a fair amount of metal there.
I'll check out rexblue thanks
I am not intimidated by it, I have a bucket loader/backhoe and straps and boards, engine hoists and jacks and whatnot and do everything myself so I can do it how and when I want that's part of the fun.
I am not in the habit of taking pictures but I am going to try to chronicle the project as I go, stay tuned ha ha
Well I wish my bed looked as nice as yours Cheddar. I'm gonna need to fab up a new 2' longer extension piece for my cherry picker engine hoist. I'll just pick the bed up and drive the truck out from under it. My goal is to roll the bed up on it's side on a pair of furniture dollies- that way I can roll it out side to power wash it. After I finish the brakes and clutch on the truck and clean and paint the back half of the frame, I'll temporarily reinstall the bed for it's trip to the sandblaster's and welder's, after which I'll bring it home to finish the bodywork and blow on a bunch of primer. After I remount it again- not for the last time though- I'll pull the cab and trailer it to a shop for some more welding as I'm able to afford the time and money toward this project.
In the past I've used four guys, an engine hoist, etc., but a year ago I made this out of scrap I had laying around. Used it to pull the bed and cab without them swinging around. I wanted something I could use by myself without worry of the sheetmetal getting scratched or banged up in the process.
That one isn't mine, this one is mine, my bed is shot, and I don't like the alternative of cutting one out of something else, I am inclined to do my bed with red oak boards with stainless strips, I will be using it for daily driving and work around the homestead. I will be pulling the cab off soon for welding two floor holes and for cleaning/priming/painting the frame with 100% new brakes, master cylinder rebuild, new copper/nickel lines, new wheel cylinders, shoes, springs etc, and all three Ebrake cables, new shocks, degrease all the running gear, new u-joints, drag link, rewire it all, then the body goes back on and paint and glass and go! You know a couple weeks Ah ha ha ha ha, we can dream can't we…
Chad,
That is interesting as the left front fender sure doesn't look like its ever been off, its got rot on the header panel that matches the fender and fenderwell that seems like it all happened together and wouldn't have been able to be taken apart a long time ago. But you have some knowledge I don't about these rigs so it most likely was changed at some point, at least it has the emblem (which the insert of is clear/faded, requires some forensics to see if I can see any numbers). The right fender was definitely changed out. I am finding skim coats of bondo over small dents that were done when they painted it all yellow. This truck was a real working farm truck and has had a couple big events at least. I found that the frame is slightly bent down in the left rear corner, bizarre, the bend point is exactly over the axle, the frame is bulged ever so slightly to accommodate it as it still runs straight horizontally, I am going to try to bend it back a little, it may straighten right out. It was this way when they did the fender and painted it as they cobbed the bumper and body to look level. The other one is that something was dropped on the hood, It took out the windshield and put a crease across the back of the hood while the impact was absorbed by the hinge brace and it is bent out. Since its the original (well at least I can tell it was white like it was supposed to be) and really only has the one crease that, as I have seen can be amazingly straightened out with some patience, I am gong to drill out the spot welds of the hinge brace and see if I can't get it back straight enough to fit in the adjustment zone of the hinge assemblies. So those fenders on your truck are the stock big opening? I can't afford fenders right now but it looks like I may be upgrading this periodically as I have it. This is to be the 100% operational and reliable homestead truck along side the 55 F-750 dumper, I'd like them to be semi showable as working antiques as I have a history of mechanics body and paint since I was a kid but not too fancy. The 750 has been sitting for three years since the bendix went and I haven't needed it, negligence, but it is slated for rejuvenation shortly after this truck is operational. Thanks for the info!
Ed
Ed
