Physical Front Axle Weight: Dana 50 TTB vs Dana 60 Solid Axle
I've done a bunch of research trying to find the axle weights of 1987-1997 front Dana 50 TTB vs front Dana 60 solid axle but can't find conclusive numbers. I was wondering if anyone had the weight specs on these axles. Just to be clear I am not looking for GAWR. I am looking for the physical weight of the axles themselves. I haven't been able to find numbers for the Dana 50 TTB and the numbers I have found for the Dana 60 have been anywhere from a few hundred pounds to over 500lbs. Does anyone know what the weights of these axles are with bare spindles or with hubs/brakes?
Good question. I'm curious as well.
Don't know if the TTB is heavier or lighter than a Monobeam, but either way I bet they're heavy!
Just a regular old 44 felt like it was every bit of 250lbs but since I never got it up and carried it completely (as if!) I can only guess.
If there is no chart available, maybe a company like Currie that ships complete axles can get us close. But I don't know anyone that sells a TTB setup complete. Just axles and gears, so that's not going to get you exactly where you need to go.
Good luck.
Paul
Good luck.
Paul
Received 3,110 Likes
on
Thanks for the info guys. I was curious about the weight as I am tossing around putting in either a Dana 60 or Dana 50 to replace my Dana 44HD TTB I have now. The truck is a 4.9 L6 so I wouldn't mind saving some weight with the small engine if the weight difference was considerable. Either axle will work for me though. The Dana 60s are so spendy these days I will probably just go with a Dana 50. It will give me the extra strength I am looking for without breaking my wallet.
rkeith213
03-06-2015 01:54 PM
78 Ranger
16
07-15-2005 03:46 PM
elemint
10-10-2004 08:56 PM
ahkmn
09-11-2003 01:01 AM
