Brake line fittings - OEM part numbers / alternate part numbers
I'm looking for the part number, OEM or replacement, for the brake line fittings for the end of the hard lines that screw into the master cylinder. Trying to cross reference what I can get ordered and OTW quickly from Amazon, or the like. I have to wait until Tuesday to get the master cylinder replacement I ordered (odd - none of the local parts shops have master cylinders for these old guys in stock anymore. Go figger). I'm not sure I trust that anyone at any of these shops are going to be able to match up the fittings, either!
This is for a 1973 F250 2WD, dual piston front disk, rear drum, 390 w/ C6 auto.
The original two that screw into the master cylinder are rounded off, and now they're chewed up from having to use vice grips to get them unscrewed.
Worse, when removing one of them the hard line was seized inside the fitting so bad that it twisted off and broke the hard line... So I figure if I'm going to cut and flare one of those lines, I might as well do both, and replace those fittings.
My truck has a master cylinder and a separate proportioning valve, and there were a couple of hard to find sizes on them for the flare nut connections. I found this kit on Amazon that had everything I needed (with the except of one 9/16" fitting) to redo the brake lines on the whole truck. Made up my own lines with some 3/16" Nicopp tubing - so much easier to work with than steel, and doesn't rust.
Maybe take a look at something like this
https://www.ebay.com/itm/Brake-Line-...YAAOSwPgxVOstB
Or have the guy at Oreillys let you go with him to the back room where they have a cabinet full of that stuff.Do yourself a favor and buy a coil of NI Copp brake line. Sooo much easier to bend and double flare with no leaks..
If you zoom in on the MC you can tell that the one in the back is larger than the front.
Do you plan on using the existing lines and adding the fittings? Are they the original steel lines? If so, I would look into replacing the steel lines as a set. If you go that route, the fittings would be part of the new set.
I do know that on mine, there were two different sized fittings going to the master cylinder.
Dirty Offio
10-18-2015 07:09 PM
Thorox
02-06-2015 03:02 PM
Macs1964F100
11-20-2013 10:44 PM
rocdril
12-20-2012 07:11 PM
