Tire wear
Old Apr 14, 2019 | 03:45 PM
Firefighter12's Avatar
Firefighter12
Tire wear
So I just had to put new tires on the front of my 95 350 2wd only had 25000 miles on cooper ht3 tires . Just wondering if you guys experience the same issues or not the truck has been lined up by a couple different people drives straight as a arrow down the road. It just eats the edge of tires. I know lots of guys around here say it’s just a dually and they all do it but if that’s the case why don’t the single wheel trucks do it either way just wondering what your experience is.
Old Apr 14, 2019 | 04:35 PM
Conanski's Avatar
Conanski
What edge is being eaten... inside or outside?
How much static camber do the wheels have?
How aggressive do you drive?
Old Apr 14, 2019 | 05:23 PM
Pickledboater's Avatar
Pickledboater
In the past my Fords have had a habit of “cupping” the outside edge, as in alternating high and low spots. Assuming your alignment is good, I minimized it by keeping up with good shocks on the front and rotating the tires often. IMHO it is kind of inherent with that suspension.
Old Apr 14, 2019 | 05:45 PM
Firefighter12
It’s the outside edge and I don’t have any numbers on caster and camber . But the last time it was lined up He did lay the driver side tire in some more for some reason I want to say 0.02 degrees positive and 1/16 toed in but don’t hold me to that. As far as driving habits it’s fairly calm other than most of the time if I’m driving it it’s got a trailer hooked to it with anywhere from 6000 to 15000 pounds on it. Don’t just ride in it a whole lot due to a 460 gets a little thirsty sometimes.
Old Apr 14, 2019 | 07:53 PM
Conanski's Avatar
Conanski
Bumper pull or 5th wheel? Either way that is probably the root cause of the problem, a heavy trailer on the back will unload the front which throws camber off and probably toe in too. As mentioned this front end is quirky like that, the wheels do not travel straight up and down they move in an arc and it's compounded by a steering system that doesn't move in sync with the suspension it actually changes alignment through it's arc.
So there is a couple things you could do, upgrade the steering to a rack style system and setup the front end camber to be more correct with a trailer attached or get a weight distribution hitch if this is a bumper tow setup. If it's a fifth wheel then perhaps move the mount to put a bit more weight on the front of the truck. Bottom line is you want the front end to remain at it's unloaded ride height or maybe a little under it when the truck is loaded to keep alignment and camber in the neutral range.
Old Apr 14, 2019 | 09:40 PM
Firefighter12
Most of the time it’s a gooseneck and I do wish the ball was further in front of the axle. It was in the truck when I got it I am currently finishing a skirted flatbed that I’m going to move the ball location up a bit. I also pull a tag along camper a good many miles a year and that makes sense about unloading the front and causing a sharper arc also doesn’t help that I run aggressive tires on the back so I only rotate the front side to side guess I’m still better than a buddy who’s got a Chevrolet that has been to least 15 alignment shops in recent years and Eats tires far worse than my old ford does
Ken Wolkens
2009 - 2014 F150
Oct 24, 2016 09:21 AM
andrewzx92000
Nov 29, 2015 07:06 AM
Mydiesel250
Apr 23, 2009 05:21 PM
FordPS
Dec 17, 2006 07:01 AM
HerbertKornfeld
Nov 29, 2003 07:03 AM
