Reverse light switch
Old Apr 13, 2019 | 04:41 PM
puppyf250's Avatar
puppyf250
Cuz its crappy and raining outside, I don't feel like laying on the ground. Does someone have a picture of the back up light switch? Want to wire in some additional back up lights, but, dont know what triggers them.
Old Apr 13, 2019 | 06:52 PM
marksman76's Avatar
marksman76
If you have a manual trans, there is a switch on driver's side of transmission with 2 wires.
One is power coming in, and the other is hot to rear backup lights.
All you need to do, I think, would be trace power light back from reverse/ tail light area and splice in your additionals near rear bumper.
Old Apr 13, 2019 | 09:46 PM
TooManyMIce's Avatar
TooManyMIce
You might get away with tapping them right into the wires for the stock reverse lights, assuming the circuit can handle the additional current. When I installed aux backup lights on my daily, I went whole-hog with a relay and fused power feed, triggered off the wiring from the range sensor on the slushbox (with an off switch for when I'm parking and don't want to blind somebody). This is probably overkill for the cheap LED pods I used, but I didn't know what the factory circuit could handle, and didn't want to find out the expensive way. Having them on their own fuse also means I won't lose anything else if they short out.
Aux reverse lights are completely worth the hassle BTW. I miss mine whenever I back up a truck without them.
Old Apr 14, 2019 | 11:27 AM
puppyf250's Avatar
puppyf250
Thanks for the help. I will be working in some LED lights under the rear bumper. Plan on having them come on when in reverse, but, also with a separate switch if need some light at hunting camp.
Old Apr 14, 2019 | 04:12 PM
marksman76's Avatar
marksman76
I had a brand new front clearance marker assembly from Ford mounted on the rear of my 1984 Nissan King cab.
I had a switch on the dash to activate it.
That way it only came on when I really needed it to.
BadMoFo
29
Mar 10, 2025 11:35 PM
fordtruck661
Electrical Systems/Wiring
Nov 12, 2012 06:41 AM
Rose Clifford
16
Aug 19, 2011 02:47 PM
tomtoc
Sep 7, 2007 12:23 PM
mohavi
Feb 26, 2004 03:11 PM
