Wrong Oil
Old Apr 13, 2019 | 04:11 PM
Otterpop's Avatar
Otterpop
Wrong Oil
I changed my oil today (2001 Excursion v10 gasser). I typically use motocraft 5w-20 After I was done changing I realized that I had accidentally put in 2 qts of 5w-30. In other words I put 4qts of 5w-20 and 2 qts of 5w-30.
Will this be an issue? Should I change out the oil again for the proper rating?
Old Apr 13, 2019 | 05:56 PM
ExxWhy's Avatar
ExxWhy
I always run 5w30 in mine, you can run either. My 2000 called for 5w30, nothing changed on the engine when Ford changed to using 5w20. You will be fine.
Old Apr 13, 2019 | 06:36 PM
WE3ZS's Avatar
WE3ZS
Welcome to the EX forum!
I too run 5W-30 regularly, it burns a little less with the heavier oil. You will be perfectly fine with your custom oil blend.
Old Apr 13, 2019 | 08:34 PM
DavenTn's Avatar
DavenTn
Sleep well and don't give it another thought.
Old Apr 13, 2019 | 08:58 PM
Otterpop's Avatar
Otterpop
Thanks guys, I will rest assured.
WE3ZS I've owned my Ex for about a year and I have not noticed any oil burning in mine. Is it common to have the oil burn away?
Old Apr 13, 2019 | 09:14 PM
WE3ZS's Avatar
WE3ZS
Some do, some don't, some do more than others.......mine drinks about a quart every 2.5 to 3k miles.
Old Apr 14, 2019 | 07:35 AM
Flyboy1100's Avatar
Flyboy1100
I have been using 0w-40 for the last 12k..... dont lose too much sleep
Old Apr 14, 2019 | 11:03 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
If you had a 7.3 or 6.0, I'd say lose sleep. Since you have The Mighty V10, rest easy.
truckfella
Modular V10 (6.8l)
18
Dec 30, 2016 01:43 PM
airmark
Feb 29, 2016 10:51 AM
bergy 2000
Jun 16, 2011 08:19 AM
who1975
2004 - 2008 F150
33
Nov 19, 2005 07:55 PM
ejpreston
General Automotive Discussion
Sep 16, 2004 07:34 AM
