'96 Trouble Code
Old May 20, 2001 | 10:56 PM
sjt_24's Avatar
sjt_24
'96 Trouble Code
I have a '96 F-150 5.0 that is getting the "check engine" light. I had a friend check the code and it came up "EGR flow insufficient". We checked the valve itself and it doesn't seem clogged. Has anyone experienced this problem before and what should I check. Is there a sensor further down the line that checks the EGR that could be bad? Any help would be greatly appriciated. I'd like to try to narrow things down before I have to give it over to a dealership.
Thanks again.
Steve
Old May 30, 2001 | 04:04 PM
dtoolman38's Avatar
dtoolman38
'96 Trouble Code
do you got vaccum at the line?........Dave1996 F150 5.0 5SP 2WD K+N Kit,Gibson swept side duel exhaust,JET module,Powertrax Locker,Shorty Headers ported to the heads,Billit short throw shifter,Sportech 1" rear sway bar w/poly bushings,more to come,too much to list
Old May 30, 2001 | 10:19 PM
sjt_24's Avatar
sjt_24
'96 Trouble Code
I have exhaust flow coming up the tube to the EGR valve but I haven't had a chance to check beyond the valve.
Old Jun 1, 2001 | 08:38 PM
jakegypsum's Avatar
jakegypsum
'96 Trouble Code
You need to make sure that the EGR valve is opening and closing when it should. If it is not moving, it could either be a bad vacuum line (or supply) to the valve or that the valve is froze up. Good luck.
Jakegypsum // Ford fleet, soup to nuts.
Old Jun 1, 2001 | 10:58 PM
knuckles's Avatar
knuckles
'96 Trouble Code
What trouble code was stored? Was it P0401? Let us know & we'll go from there.
Old Jun 2, 2001 | 05:50 PM
jakegypsum's Avatar
jakegypsum
'96 Trouble Code
