Carb help needed
Old Apr 12, 2019 | 07:44 PM
Jerome227837's Avatar
Jerome227837
Carb help needed
I have a 360FE that I am bringing back to life. I have finally been able to get it to idle on its own but it’s running way to high rpm. The adjustment screw is not touching the throttle control lever at all. However I can put pressure on the lever and the idle slows down to a normal speed.
Old Apr 12, 2019 | 07:52 PM
john jamieson's Avatar
john jamieson
With the air cleaner off and the choke open, look down the carb at the butterfly valves. Are they fully closed or only closed when you push on the linkage? Do they move freely?
john
Old Apr 13, 2019 | 09:54 AM
beartracks's Avatar
beartracks
Sounds like your throttle cable/rod or the kickdown lever (if auto) is holding you back.
Old Apr 13, 2019 | 10:01 AM
FuzzFace2's Avatar
FuzzFace2
or the choke fast idle cam is hanging up.
Disconnect the throttle cable & kick down rod to see if they are the issue and check the fast idle cam.
Dave ----
Old Apr 13, 2019 | 11:19 AM
Jerome227837
john
they are open just a little. Only had time to take the pic this morning will try to mess with it more this afternoon.
BGF100
Jul 21, 2016 12:08 PM
1954F250
Sep 4, 2008 11:11 AM
MRStace84
Nov 11, 2003 09:22 AM
20ranger
Jul 1, 2003 11:32 AM
gadams
Mar 13, 2001 02:10 AM
