351m - Removing smog stuff.
But if you don't have the choke stove beside your manifold, you probably have a single vacuum line that should be going to some sorce of heated water on your engine via vacuum port.
During the 70's and 80's, Ford used (3) different varieties of chokes: Electric choke; Vacuum choke, and the hybrid Electric/Vacuum choke. The latter sounds like what you have. So yes, I'd tie into one of the vacant ports since this is not really a pollution device but serves actually as a thermal signal for your choke.
(Edit: this anaolgy corresponds to the diagram on Bubba250's web site. What I am calling a "Vacuum choke" is what he titles - probably more correctly - as a "Hot-air choke")
I've been doing this for a long time, trust me, no air pump, no fire in the cat...
...On a side note. I ran a 78 LTD II with a 302 in it that had 2 cats right off the manifolds for 5 years with the air injection tube removed from the back of the heads, 2 bolts plugging the holes and no pump. I never plugged or melted a cat...
...If everything is working properly you have no EGR at WOT, that means the carb has to deliver enough fuel at WOT to feed the whole engine. and since that is when most pinging problems happen. I would have to say that you will be just fine with the stock jetting.
In the second place you're wrong about ping not happening at part-throttle. It's just as common.
There is a small vacuum port from the carb that causes positive air flow and draws the heat into the choke.
The rubber tube you describe simply went to a port on the air cleaner, to make sure that filtered air was drawn in.
If your choke is now electric, simply plug it off with a vacuum cap. It's a small vacuum laek, nothing more.
I have kind of the reverse question than kjkozak has. I have a 77 f-150 4x4 and I have the strangest feeling that it doesn't have all its smog equipment. And since I need to get it smogged for registration, I need a good reference for what should be there.
As for Smog pump versus egr versus catalyst:
The thermactor system existed before catalysts/catalytic converters. It was intended to burn excess hydrocarbons IN the exhaust manifold by injecting fresh air. I expect that that has the side effect of increasing exhaust velocity, both from the air injection and from the fuel lighting off in the exhaust manifold (think turbojet here)(or rocket engine for that matter).
I don't think it is critical, but I think it should be pointed out that the Thermactor system had been in use since at least 1969, whereas the 351M/400 were designed after that point with the Thermactor system in mind.
The catalyst/catalytic converter explicitly requires the air pump to function correctly:
"The catalytic converter system requires the use of a secondary air source (Thermactor Air Injection System) in order to maintain the converter feed gas (exhaust) oxygen content at a level high enough to obtain maximum oxidation of the hydrocarbons and carbon monoxide in a catalytic reaction." -- Motorcraft Vehicle Emission Control Systems manual volume II (1975)
A catalytic converter is designed to maximize the surface area of the catalyst elements exposed to the exhaust, so it always reduces exhaust velocity, and so it will accumulate deposits from the exhaust, and if that stuff isn't cooked off regularly it's going to clog. (How rapidly I cannot say.)
Given the above, to my mind, shutting down the air pump without removing the converter is probably pretty dumb, since you won't reduce emissions but you will reduce exhaust velocity. On the other hand, the air pump running without the converter is going to reduce emissions and may increase exhaust velocity, which in turn is going to increase the amount of O2 pulled in through the carb. (There's a tradeoff involved - how much power is consumed by the pump pulley versus how much gain you get from running the pump. I don't know the numbers or I'd figure it out.)
This needs a good test.
I'd be interested to know how extra air from the Thermactor affects the O2 contents of the exhaust gasses recirculated through the EGR.
ash
['Complicated interactions.']
Just as well, since the O2 added to the exhaust gas does create a secondary combustion and additional heat, which you probably wouldn't want in the intake manifold anyway.
