Obs cab swap.
Old Apr 11, 2019 | 01:14 PM
Piggad32's Avatar
Piggad32
Obs cab swap.
Swapping out a 96 f350 powerstroke cab with a 96 f 150 cab. Any tips? Wiring harness etc
Old Apr 11, 2019 | 01:16 PM
jas88's Avatar
jas88
You will need to use the PS truck's wiring inside the cab, at least the part behind the dash for sure. If the interiors are the same color, I would swap the entire dash with wiring and all from the PS truck to the F150 cab.
Old Apr 11, 2019 | 01:21 PM
Piggad32's Avatar
Piggad32
I will be swapping the dash. Interior is same color. Thanks for the input
Old Apr 11, 2019 | 07:42 PM
Diesel_Brad's Avatar
Diesel_Brad
Just use the cab shell. Reuse EVERYTHING else from the diesel
Old Apr 11, 2019 | 11:02 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
Do what you have to and retain the F350 VIN.
Old Apr 12, 2019 | 07:13 AM
Diesel_Brad
Well that mean not using the f150 cab. it is technically illegal to put the f350 vin onto the f150 cab
Old Apr 12, 2019 | 07:45 AM
frank5079's Avatar
frank5079
Actually no it isn't. When our techs replace cracked dashes here at the dealership, they remove the original VIN tag and rivet it back onto the new dash. I did the same when I changed interiors on my '84 CRX from blue to black...
Old Apr 12, 2019 | 02:18 PM
Roger T. Pipe's Avatar
Roger T. Pipe
How do you address the tag on the door pillar?
Old Apr 13, 2019 | 07:07 AM
Diesel_Brad
Completely different. You are NOT transferring the vin to another vehicle
Old Aug 9, 2020 | 08:58 AM
Negative Covfefe's Avatar
Negative Covfefe
This is a felony. I hope you used the correct rosette rivets on the tag, because if a cop even glances at the tag and sees non-rosette rivets, it's jail-time for you.
Just selling rosette rivets is illegal in many states for this reason.
Old Aug 9, 2020 | 10:22 AM
matt167's Avatar
matt167
Most states have paperwork to do it legally. In some cases both titles essentially get bonded together and the state may issue their own VIN
As far as swapping vin plates at a dealer, Well Ford actually will sell you a brand new cab for their trucks ( current model years ) which will not have a Vin on it. ... OBS trucks have the VIN on the door frame, the emissions sticker, the dash and also a partial VIN on the right frame rail
Old Aug 9, 2020 | 03:20 PM
Edgethis's Avatar
Edgethis
You could always call your states dmv and ask if there is a proper method they accept.
I've seen this question come up alot, more frequently on the older mustang sites. Really depends on the state. Some don't seem to care, some make you get an inspection by a state trooper or certified shop.
needs more mudd
Sep 13, 2014 07:55 PM
gnarles
Jul 4, 2011 01:26 PM
90F250351
Feb 5, 2007 10:43 AM
90F250351
Paint & Bodywork
Jan 31, 2007 01:59 PM
