Okay I need help! I have a bad memory steer issue going on with my 2005 excursion. I’ve done a lot of front end and suspension work recently and I can figure out what is causing the issue. It started with needing new ball joints and shocks so I did those. Then I put a 2 in leveling kit on with dual steering stabilizers. Then added a leaf to the rear to bring the rear back level with the front. I put 20 in 2018 f250 wheels with 34 in tires on and 2 in wheel spacers. Put new sway bar end links on the front to get rid of the clunking (which is now gone) I put a new power steering pump and steering gear box on which didn’t improve anything. Put a Hellwig sway bar on the rear, that got rid of the wander for the most part but still experience some bump steer. So I went back to the ball joints thinking they were the issue replaced the duralast ones with moogs and still no improvement. I just don’t know where to look anymore. Wondering if anyone has had similar issues with memory steer on theirs and any suggestions where to look.
If by memory steer you mean you have to manually return the wheel to straight, that has to do with new ball joints and steering box. When I did the ball joints, I had a bit of that for a while and then again when I did the steering box. It will loosen up after a while. Mine is fine now and super tight but returns on its own. Be patient.
From your suspension upgrade thread:
Am reading correctly you raised the rear ride height by adding a leaf to the stock spring pack ?
Running Bilstein “Ex” valved 5100 shocks ?
And then added a hellwig anti-roll bar ?
what are the exact alignment specs you are running with that combination ?
Yes I added a leaf to the rear pack and have Bilsteins not the 5100 but the yellow ones but they said they were good for 0-2 in and it only raised it 2 in. And then yes I added the rear sway bar. The wandering isn’t bad just the memory steer and bump steer. I know it’s not the ball joint cause I did a nearly 2000 mile trip to Hilton head and back and it didn’t improve at all but that was on the duralast ball joints
The critical question of my previous post was about your current alignment specs.
if you can post a picture of your current alignment specs I can likely tell you what your issues are.
Ball joints are probably over-torqued. When i was a young pup first wrenching on cars, I swapped a set of ball joints on my F150. tightened the the ball joints until I could not tighten anymore. I may have even used a floor jack handle on the breaker bar. Had the truck aligned. I had the worse memory steer ever! Luckily my dad was able to set me straight and pass me a torque wrench and the correct torque specs. If I recall upper ball joints are 69lb-ft and lowers are 45 lb-ft and than final pull to 150 lb-ft.
My spindles being over-torqued did move with some effort. once I corrected the torque the spindles moved freely and smooth.
I agree with this but the troubling part of the story is the OP installed Duralast BJ and when they had memory steer he replaced them with moogs, I supposed it possible his torque wrench is so far out of spec he just keeps over tightening them... hmmm
Also, since I didn’t see you mention anything about a track bar or pitman arm I assume you did not alter these and both are stock. Is that correct ?
While i am verify a few assumptions, is your steering dampener new or the same one you have had all along ?
a few pics of your front end and these parts would help in a proper diagnosis
EDIT, you said “they” Said the yellow Bilsteins.....who is they ? And is the same they that installed your ball joints ?
I did all the work with my father in law who is a diesel mechanic. And yes the pitman arm and track bar are stock but that shouldn’t be an issue with only a 2 in lift. It’s a new dual steering stabilizer from rough country. And the front I have 5100 series shocks and the tears are the 4600 yellow Bilsteins. I only got those cause I wasn’t expecting the leveling kit to make the front end so much higher than the rear and was planning on keeping it stock height but the yellow ones seem to be doing fine. And the ball joints are not over torqued cause I was thinking that with the first set of duralast so I swapped them with moogs and have the same issue. Ford is emailing me the alignment results cause they never gave me them so when I have them I’ll post it. But here are some pics. Don’t know why the grease fitting is hitting my u joint knuckle???
When I installed my recent lift kit, I went 10 lb-ft too high on the upper ball joint. (I adjusted torque wrench too high) Just 10 lb-ft was the difference between a nice smooth spindle movement and a spindle that moved with more effort. I used my late father's pristine snap on torque wrench that is calibrated once a year. I would check the torque again. if the spindle doesnt move smoothly with zero to little effort that would probably be your issues.
i see a few issues but am out ruuning errands so i will type up a proper reply when i get to a computer in awhile..... hopefully you will have those alignment specs by then.
yup...... learned that in my aerospace days, torque wrench was required to be calibrated before each new task so sometimes once a day. obviosly overkill on a typical street vehicle but the lesson is the more critical parts required more attention to torque specs.
May I make a suggestion? You mentioned you added wheel spacers. Most suspension setups,even from factory have a touch of bump steer, it's a pain to mitigate even with a solid axle. The further you push the center of the tire out past the pivot axis of the kingpin, you magnify any bump steer in the steering system. When we were trying to overcome factory bump steer on our racing quads (I know A-Arms, different animal) we developed a mini rack system to make the tie rods equal to the arm length which helped and then had to widen the front to get the desired width while having custom negative offset wheels made which tucked the kingpin axis almost center over the tire.
That way what little bump steer was present was not amplified by the wheel being away from the kingpin axis. I know a wider stance is preferable, but did you drive it before installing the spacers? If not it may be worth a shot, and a free one to see if that helps.
