Radio for '66
Yes, but you end up with a mono out, low power radio and I'm guessing relatively high distortion on the aux in such that you can barely hear over the wind noise. I want to plug in my USB stick holding an SDC card jam packed with enough music to listen to for a week without ever hearing a repeat... in stereo, loud and clear enough to drown out my own singing.
If you already have a good circuit board type of soldering iron then for less than $10 in electronic components and bits a person can add a jack to the original AM radio to be able to plug an MP3 player (iPhone, iPod, etc.) into it. Then you can play any content you have, streaming, etc.
https://www.instructables.com/id/Add...layer-to-an-O/
That's the coolest thing i've seen all day. Tektronix, eh? Those things cost as much as a house at one time.
Here's a video I made a while back. Sort of fun to watch and a great partial song, but this is what the AM Radio receives through the input jack if one is added.
https://www.youtube.com/watch?v=pypgutZ1Vg0
That's 3 watts of pure vacuum tube power baby!! Solid state transistor distorts differently than hollow state, square wave odd order distortion is very harsh to ears. That's one reason tube amplifiers are favored by guitarists, they sound better as they go into clipping gracefully, instead of blowing speakers.
I remove all of the + or - 10% range old carbon resistors and replace them with new wire wound 1% military grade resistors. It helps reduce station drift due to components changing value as they heat, etc. and if you want FM you could try pulling up you favorite FM station on your phone directly or using iHeart radio and stream it. This way, too, you can still listen to your favorite stations even when you are out of town.
1964-66 eliminated all tubes and uses only transistors. If you look at the face plate (assuming it has not been swapped out) of the various years if it has a 12 in the dial numbers it is a tube radio and if it has a 13 in the dial numbers instead it is a transistor only radio.
1964 - 4TBT - Truck
1964 - 4TBU - Econoline
1965 - 5TBT - Truck
1965 - 5TBU - Econoline
1966 - 6TBT - Truck
1966 - 6TBU - Econoline
1966 - 6TBB - Bronco
Interestingly, vacuum tubes basically have an indefinite shelf life. So long as the envelope isn't broken, they are good to go. Transistors run into problems. Germanium types are getting hard to source for some applications. It is true there are universal replacements but they don't always work quite right. For an AM radio it wouldn't matter. It looks like they used a hybrid design? Transistor for the audio output, and tubes for the RF and IF section. Interesting.
There is a strong vintage radio club, mostly non-automotive, here in the Bay Area, they regularly hold swap meets. Around 20 years ago, I was into vintage radios, and was told that Japanese buyers started snatching up old vacuum tubes at these meets. Apparently, at that time at least, collecting classic American radios was coming into vogue in Japan .They were paying higher prices than had been common, creating shortages. That is exactly why I never balk at buying NOS parts - they’re not making any more of them, and they are not likely to go down in price or become more common. Gotta pay if you want to dance.
Anything branded Western Electric for a time was going for stupid money, transformers, hookup wire, horn speakers, even rolls of Western Electric solder would garner pretty damn good money. Cloth covered wire. But there definitely was an effort by a few individuals to scoop up the desirable types of US and European NOS output tubes. Hi-fi folks can get really weird and obsessive. They claim to be able to hear differences in vintage wire, it sounds better, special power cords, you name it.
#29
Yeah, Ted, it is still happening here, and was when I was restoring a couple floor console radios from the 30/s40s. And at least out here, was way more than just two guys. The Japanese also, at that same time, had a taste for some big classic American cars and were, I am told, causing prices to rise in that area. They have good taste, I don’t blame them, they are smart. And beside, alls fair in love, war, and capitalism!
