Code P2074
Old Apr 9, 2019 | 02:51 PM
Michael B. Sweet's Avatar
Michael B. Sweet
Code P2074
I keep getting this code and I have no idea why, it started after I changed my fuel filters for the second time, the initial fuel filter change was done by the ford technicians in Florida. Any help would be appreciated.
Old Apr 9, 2019 | 05:08 PM
TeddyD's Avatar
TeddyD
Is your air filter dirty? That code could be MAP sensor related. Check your air filter and clean your MAP sensor on the air intake. Here’s some info but I’d bet it’s the MAP sensor.
P2074 FORD - Manifold Absolute Pressure/Mass Air Flow - Throttle Position Correlation at Higher Load
Possible causes
Large vacuum leak on the engine
Faulty Manifold Pressure (MAP) sensor
Faulty Throttle Position Sensor (TPS)
Faulty Engine Control Module (ECM)
Old Apr 9, 2019 | 07:26 PM
Tom's Avatar
Tom
Hey Michael, welcome to FTE!
Just to clarify, you have the 6.7? If so, I will move this down to the 6.7L Power Stroke forum, you should get some better responses down there. Just let us know!
rstinson
6.7L Power Stroke Diesel
Mar 17, 2018 04:26 PM
StorMay05
1997 - 2003 F150
May 11, 2013 05:12 PM
femaletrucklover
Oct 9, 2006 05:52 PM
Jrock909
Jan 18, 2005 08:50 AM
robodeb
Jul 4, 2003 08:58 AM
