HELP 2003 E250 Sway Bar Bushing HELP
https://www.autozone.com/suspension-steering-tire-and-wheel/suspension-bushing-kit/energy-suspension-suspension-bushing-kit/388218_400971_5934
I had a guy do it for me since I had not done it before. I did watch several vids on it and whatnot. The end bushings are what Im having issues with. Within a day of installing the new bushings, they popped out. This is a pic of the bushings that were installed
These go into the existing sleeves of the old bushings. you remove the rubber from the old bushing and these are pressed into the sleeve of th eold bushing. They do have available to older type with the metal sleeve to replace old ones, but I went with these because thats what came in the kit. So yesterday, I pulled it apart, and removed the bushings and replaced with new ones
Not even 24 hours later they popped out too.
So.... Im asking you guys who have experience with this, what is the trick? Should I bite the bullet and get the OEM type with the sleeves and have them installed?
I installed the bushings exactly like in this video, and they were well seated on the front, but did not extend out the back of the sleeve as the sleeve is longer by a hair than the bushing that went into it.
https://youtu.be/ba-XMJsFqKM
The urethane bushings are best as they don't degrade over time so they keep the sway bar in contact with the I-Beams.
That type bushing simply won't physically fit in the I-Beam with the OEM sleeve still in place. Others who've used urethane bushings have always encountered problems with removing that steel sleeve---it can be a PITA unless you're working with a full frame/body lift.
