Offroad & 4x4
Track Bar Bushings
Old Aug 17, 1999 | 04:43 PM
Henry Rowlison
Guest
Posts: n/a
Track Bar Bushings
Old Feb 15, 2001 | 10:47 AM
2beers's Avatar
2beers
Track Bar Bushings
Anyone know procedure to install Track Bar Bushings? Have already screwed one by grinding a taper on one to start it. It's in but not fitting proper.
Old Feb 24, 2001 | 11:30 PM
Nod's Avatar
Nod
Track Bar Bushings
2Beers, I recently changed uot the track bar bushings on my 71 F100 4x4. I used new poly bushings from Energy Suspension, they went on tight but not so as to have to grind them down.I have heard that new factory rubber bushings are very difficult to install without a press of some sort.I would say if you have to grind on them then the tight fitment that is needed would be compromised. Hope this helps.
"bowties in the rearview mirror"
Old Feb 27, 2001 | 07:23 PM
rfitz's Avatar
rfitz
Track Bar Bushings
Not sure if they are like the ones for a 76 Bronco but if they are make sure you have the entire old bushing out. Had the same problem and tried the same grinding. Then spoted the metal sleeve that was around the original bushing. Once it was removed, new bushing went in a lot easier.
