Rooftop Antenna Relo Kit!
A rooftop antenna relo kit for the 2013 - 2019 F-series appears to be on the way from Ford:
https://madocumentupload.marketingas...658df&v5=False
Woo Hoo!
Jim / crewzer
Woo Hoo!
Jim / crewzer
Received 6,693 Likes
on
Woo Hoo!
Jim / crewzer
Woo Hoo!
Jim / crewzer
My take is the original antenna remain in place but be disconnected. Our camper’s front overhang clearance is OK.
The new antenna looks like a new shark fin.... I have other taller stuff on the roof of our camper, so I don’t foresee our overall clearance (~12 ft) getting worse.
Did I understand your question correctly?
HTH,
Jim / crewzer
HTH,
Jim / crewzer
on
On my 2019 F450 I’ve been thinkin about installing another antenna on the black plastic cowling below the passenger side windshield wiper. . I think that location would be far enough ahead of the TC cabover that reception won’t be shadowed. I hope that location would work cuz I don’t want to put an antenna on the hood.
Received 3,992 Likes
on
I saw a new model GMC pickup in town yesterday and it had the 'shark fin' mounted on the roof curve right at the top edge of the windshield. Reminded me of a Unicorn horn sticking out there. It was parked in the Wally World parking lot and I never saw the owner. It made me think of this thread and I was curious as to who and how it came to be mounted like that.
Easy fix as far as Sirius radio antenna is concerned is to run a separate antenna behind the dash, through the firewall to the engine compartment and secure it out by the front of the hood. Had the antenna on the top part of the windshield and was fine until I dropped the camper on then it got spotty reception. Moving it out to the front of the hood and all is good. They are weatherproof antennas also.
Well, one problem is that the Sirius mag mount antenna won't stick to the aluminum body.
I checked out the antenna wiring yesterday and found that from the radio the antenna wire crosses over to the passenger side, then up through the A pillar to the antenna puck. Mine is satellite only, no GPS.
There is a Fakra connector that is accessible by dropping the glove box door, and another connector under the headliner near the top of the pillar.
I ordered one of these from Amazon.
Once the adapter cable gets here I'll try the antenna on the dash. If that doesn't work I'll have to figure how to thread the wire out and up to the hood area.
Eight0six,
Can you share a couple things about your install?
Where did you purchase the antenna........, part number, cost, etc.
Connecting the antenna.........., where is the connection point under the dash, and what is the best way to access it, and was that cable adapter mentioned in your previous post required?
Thanks
Thanks
