Throttle linkage
Apr 4, 2019 | 07:39 PM
Throttle linkage
Has anyone successfully repaired the crazy "trapeze" throttle linkage by installing bronze or nylon bushings?
Apr 5, 2019 | 01:08 AM
Quote:
Originally Posted by
mrpotatohead
The bushings were not available by themselves, you had to replace the whole enchilada.
I don't know if you could replace the bushings, even if you could find some that would work.
Upper pic:
Apr 5, 2019 | 05:15 AM
It doesn't have bushings originally, I'm talking retrofitting new ones. It's definitely do-able.
Apr 6, 2019 | 02:55 AM
I don't see why it couldn't be done. It's the same idea as installing bushings on the carb plate rods. You would just have to find, or make the brass/bronze bushings. Then enlarge the holes in the brackets to accept the bushings. If you're set on keeping the original linkage, it could be done.
Apr 6, 2019 | 05:47 AM
I think I'll tackle it since I can't seem to find a new one for a 302.
Apr 6, 2019 | 02:02 PM
mrpotatohead
There are
eight available NOS
Apr 6, 2019 | 04:03 PM
Apr 6, 2019 | 04:34 PM
mrpotatohead
Thanks honey.
You're welcome sweedie...
Apr 6, 2019 | 09:10 PM
Apr 6, 2019 | 09:19 PM
mrpotatohead
D
0 TZ-7A185-A ?
A/T & M/T are the same.
NOS PARTS SOURCE in Olathe KS has
1 = 913-220-5746.
OBSOLETE RELIABLE PARTS in Nashville GA has
3 = 229-686-5101.
NOS PARTS LTD in Waxahachie TX has
4 = 972-937-2201.
When the 2nd digit of the prefix is a zero, it can also be typed as the letter O, but...
All of the above are listed as D
0 TZ .. Usually you can find more parts with the letter O.
Apr 7, 2019 | 06:48 AM
Apr 8, 2019 | 10:25 AM
Got her coming from Obsolete Reliable, 60.00.
Apr 8, 2019 | 07:42 PM
mrpotatohead
Hybris
1997 - 2003 F150
Feb 26, 2011 07:31 PM
650
Jul 5, 2010 08:56 AM
jds1971
Dec 1, 2003 01:05 PM
The Man
Aug 21, 2002 09:37 PM
69F350
Aug 30, 2001 05:58 PM
