Carburetor
Old Apr 4, 2019 | 07:08 PM
Watersedge's Avatar
Watersedge
Carburetor
Forgive my ignorance, but I am learning as I go. I have a 1969 F100 with a Ford 360. What is the plate/riser (don't know actual name) under the carburetor that has an intake for coolant on the left side and possibly a vacuum line connection on the right side as you look at it from the front of the vehicle called? Where can a replacement be purchased? Thank you in advance.
Old Apr 5, 2019 | 01:12 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Carburetor spacer plate.
Old Apr 5, 2019 | 05:34 AM
Watersedge's Avatar
Watersedge
Thank you!
Old Apr 6, 2019 | 02:48 AM
GaryKip's Avatar
GaryKip
Most people remove the Heated spacer plate, and replace with a plain spacer plate. The idea behind the heated spacer plate was to prevent the carb from iceing up in cold weather. But in the summer most of us have found that the plate contributes to "perkcolating" (or boiling) the gas out of the carb fuel bowl, after the truck is turned off. Then the engine has a hard time starting the next time. While the composite ones are the better choice ( they don't transfer the heat from the intake manifold) many have used metal ones just fine. You can find them at your local parts stores, or places like Summit Racing.com. If you decide to remove the Heated spacer plate, then you need to change how the heater hoses are running by replacing:
your local parts store should have this.
Old Apr 6, 2019 | 08:15 AM
Watersedge's Avatar
Watersedge
Carburetor
Thank you so much for providing such a thorough answer to my question. I think I will remove the heated spacer and replace with a solid spacer. Thanks again!
fordboy300
20
Jan 8, 2013 03:22 AM
JRB65
Dec 12, 2012 08:32 PM
JLb300
Jun 23, 2004 03:01 PM
coug
Nov 11, 2003 11:31 AM
curti
Dec 25, 2000 03:38 PM
