Which Radiator?
Anyone have a suggestion on a good radiator for my '69 F100?
It'll have a 370 HP Blueprint Engine.
Should I go with a replacement type?
Copper?
Aluminum?
2 Row? 3 Row? 4 Row?
https://blueprintengines.com/product...block-bp3060ct
I'll check NAPA. Thanks!
The radiator support used with the Super Cooling radiator has a larger opening radius.
The benefits in the article aren't really applicable for the OP.
-Better cooling - maybe but is it necessary? Perhaps if driving in the southwest US. I went up a lot in cubes and HP and stay cool with the stock radiator (I added a shroud) even when towing a 5 ton fifth wheel.
-Lighter - Yeah, but probably not important in a truck unless drag racing.
- Corrosion resistance - Aluminum might be better in theory but not in real world application.
Shrouds are definitely a good idea if doing city driving or other slow traffic.
However, it was written by a company who sells aluminum radiators, so I have to consider that too.
I just bought a new fan shroud before I knew I was going to be replacing the engine.
LMC and others sell factory style radiators, so i can get one. I had pretty much settled on a standard factory replacement....until I read this article. Now my thinking is all muddy again :-)
I am in Middle TN and doubt if I'll ever drive this truck over 2 or 3 hours from my house. It does get warm here in the summer, but I'm not going to drive enough for this to be an issue.
I would change my coolant as required, and I would use distilled water.
I have a new fan shroud.
Weight is not an issue or concern.
Aluminum cools better hands down. That is why all new cars come with aluminum radiators.
This is my go to link for the difference in aluminum vs copper. They explain it much better than I can: Aluminum vs copper
Edit: just saw Gary beat me to the link haha.
I wouldn't worry too much over the radiator decision or let the article muddy the water. You'll be okay with either. Years ago, I replaced my factory 352 with a 390. I was worried about engine cooling too so I read about aluminum radiators and electric fans and decided to stay stock. I towed a 5 ton trailer a few times through the Appalachians in the summer and never went above 220 with the stock radiator. Now I have an even bigger FE engine making over 500 hp...still the stock radiator and still stay around 180-190 unless the weather is 80 plus and I'm towing the trailer...then maybe hit 215.
Remember to check plugs to make sure your carb is not too rich or lean. Also remember to check timing and consider adjusting the curve once the engine is broken-in. Factory timing curves are okay but can benefit from optimizing. Wrong fuel mix and wrong timing will hurt engine cooling.
There is a "sweet spot" for engine temp. I like to see at least 180F to drive moisture out of the oil.
First off,..... As NumberDummy suggested,.... Did u ever figure out which Radiator Support you have in the truck? Super Cool rear mount or non Super Cool flush mount? This will drive which Radiator you will need to buy as they mount completely DIfferently.
Lee
Does that tell us which one it is?
