Sponsored by: Real Truck
POWERSTOP BRAKE KIT
Old Apr 2, 2019 | 10:21 AM
Diamnd1's Avatar
Diamnd1
POWERSTOP BRAKE KIT
Has any one used the Powerstop Brake Kit K1906-36? What is your experience? TIA
Old Apr 2, 2019 | 12:25 PM
wizkid00104's Avatar
wizkid00104
I used the rear kit and I have these rotors up front. I would absolutely buy them again. Good solid stopping power and they solved the warping problem I was having with non-vented rotors.
Old Apr 2, 2019 | 01:28 PM
Diamnd1's Avatar
Diamnd1
How many miles do you have on them?
Old Apr 2, 2019 | 01:36 PM
wizkid00104
23k on the front rotors, 28k on Wagner front pads, 19k on rear pads and rotors
Old Apr 2, 2019 | 02:09 PM
Diamnd1's Avatar
Diamnd1
I have had 2 sets on the front and one set on the rear. Both have developed severe warp when heat builds in the front in under 5k miles. If they are cold, no problem, but once heat builds I get increased pulsation that is proportional to heat soak. Yes the break in procedure was followed to a T. The truck does not see severe duty, only pulls a camper a few times a year. I do not have a frozen caliper and have not submerged the front while brakes were hot in any water.
I called Powerstop both times to explain the situation. NO help. Only if they have a crack. The old fronts did not, I have not pulled the current set off to check. I am not happy with them. I am just inquiring if anyone has had the same experience.
Old Apr 2, 2019 | 02:25 PM
wizkid00104
Oh ok. I developed my warp in the old brakes while pulling a 1500lb atv trailer and had the bed and cab loaded down. It hasn't been a problem with these new rotors but I do not have their pads on the front. I am due for front brakes in a few months and I had every intention of using Power Stop again. Seemed to be good quality for the money. I'd like to try EBC, but they are a LOT more expensive.
Tuquala
Jan 24, 2017 08:06 AM
jpankask
Dec 12, 2016 11:02 AM
00wypowerstroke
15
Apr 4, 2015 03:30 PM
JoeMarine
Sep 2, 2003 02:29 PM
mtflat
Nov 7, 2002 07:26 AM
