I could use some help identifying this
Old Apr 1, 2019 | 07:24 PM
RTennant71's Avatar
RTennant71
This is on a 1980 ford f100 strait 6 1 barrel carb flairside pickup.
There is this tube which exits under the EGR value and returns to the manifold. Unfortunately it got twisted. Bolts rusted caused this.
Anyway. Does anyone know what this does.
Can I remove it completely?
I am trying to see of this may cause the truck to idle poorly.
Thanks
When it returns to the manifold it got twisted.
This is the tube I am attempting to identify
Last edited by RTennant71; Apr 1, 2019 at 07:28 PM. Reason: forgot to enter truck info
Old Apr 1, 2019 | 07:59 PM
Franklin2's Avatar
Franklin2
The EGR valve stands for Exhaust Gas Recirculation valve. That tube is where the valve gets the exhaust so it can put it into the engine via the intake manifold. If your EGR is not hooked up, and you do not have underhood inspections, you could plug that off somehow. You could probably cut it off with a hacksaw near the manifold, smash the end and then fold it over like a toothpaste tube. That is just a idea off the top of my head, someone else may have another better idea to plug it if you do not need it anymore.
Old Apr 1, 2019 | 08:43 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by RTennant71
1980 F100 300 I-6.
Bolts have nothing to do with it, because there aren't any.
So what else is new?
This is a very common problem: The tube itself has fittings, they threads into individual fittings that thread into the manifold.
Over time rust causes the fittings on the tube to become rusted to the fittings on the manifold, so when you attempt to remove the tube it twists, may split open.
E0TZ-9D477-B .. EGR Tube to Exhaust Manifold / Obsolete
1980/83 F100/350, Bronco & Econoline 300 I-6 except Canada except CA emission.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 71 = 800-476-9653.
See the 9D477 tube in the truck parts catalog pic .. Notice the two fittings it threads into.
GLR
Nov 3, 2018 09:36 AM
jle70
May 15, 2016 09:18 PM
greenn17h
Dec 9, 2012 07:09 PM
BarnieTrk
WTB - Parts & other
Mar 26, 2010 05:12 PM
bansheeduner
Feb 17, 2008 04:59 PM
