Vacuum Return Line connections
Old Apr 3, 2019 | 10:14 AM
Crop Duster's Avatar
Crop Duster
Perfect!! --------------
Old Apr 3, 2019 | 10:34 AM
Tedster9's Avatar
Tedster9
They work good, for the initial reef 'em down use some erl or something, it's a crush type fit and then it is semi-permanent and the fitting won't get lost. They are kind of a PITA to adjust vacuum advance, but overall it works good and looks clean, they don't leak. Took me a while to find them %#'@!! things too!
The original steel line on the 292 looked like it had been used as a coathanger numerous times to unlock the doors, rubber splices, etc. In the interim, the fittings naturally went missing eventually. Y-blocks used that style of distributor for just a few years. Stainless vacuum line would look good, but it is trickier to get a good flare I bet. When I found a good vac advance can to use, I couldn't locate that goofy connecting hardware. Only took 20 years!
ct50f1
Feb 13, 2026 05:01 PM
72CC428
21
Oct 28, 2016 07:48 PM
mtbrgeek
Oct 20, 2014 12:28 PM
Incompatible
Oct 12, 2012 02:40 PM
ReAX
General Automotive Discussion
Dec 11, 2006 11:36 AM
