Smells like brakes?
Old Mar 30, 2019 | 04:03 PM
HKEadventures's Avatar
HKEadventures
Smells like brakes?
My new F350 seems to smell like the parking break is stuck on. Or some type of smell. It happens after driving. Can’t figure it out.
is having a kind of burnt weird smell normal for a new truck with now 500 miles? Could it be something with the exhaust. Is that the new burning off or is something maybe wrong with it?
Old Mar 30, 2019 | 04:55 PM
seville009's Avatar
seville009
Catalytic converters can smell/burn for a while. The smell should be lessening over time though.
Old Mar 30, 2019 | 04:59 PM
RONMCHUGH's Avatar
RONMCHUGH
Romcjr
If it's a diesel it could be exhaust after a regen .
Old Mar 30, 2019 | 05:22 PM
Rockinfigs's Avatar
Rockinfigs
Sounds like regen
Old Mar 30, 2019 | 05:32 PM
STIBUILDER's Avatar
STIBUILDER
I got right about 2k on mine and i get a similar smell when towing my trailer.
Old Mar 30, 2019 | 07:25 PM
FATC1TY's Avatar
FATC1TY
It’s a regen taking place. Generally happens every 500-600 miles I’ve found.
Your exhaust will be HOT!!!
Old Mar 30, 2019 | 09:41 PM
HKEadventures
Does it say when it’s doing a regen? It is a diesel.
Old Mar 30, 2019 | 10:11 PM
Toledo's Avatar
Toledo
its a regen, you probably parked the truck as it was going through it.. sometimes you won't notice the smell because it'll happen as you're driving and it'll be over once you parked, its normal, one way to know if you're going through a regen look at your milage, if it drops to about 10 mpg(at least for me) its going through a regen
Old Mar 30, 2019 | 10:31 PM
HRTKD's Avatar
HRTKD
My truck smelled so bad the first time I pulled my trailer that I thought for sure it was on fire. Nope. Just burning off residue from the increased heat due to towing.
Old Mar 31, 2019 | 08:34 AM
eryoung's Avatar
eryoung
Really sounds like your describing a Regen, I have a 2017 and I was wondering the same thing a couple of weeks after I got it home (around 500 miles) I parked it and could smell a burnt break pad smell. It was a Regen. I have a XL and really wish they had a light or message just to let you know it going through a Regen. You will definitely see your mileage drop though!
Take care and enjoy your Truck!
Old Mar 31, 2019 | 08:42 AM
Flyct's Avatar
Flyct
FTE Community Team
There’s no visual indication when its doing a regen. Don’t worry about it. If you are on interstate when it’s doing a regen and you are monitoring your instant MPG you will see it drop considerably. Mine goes from about 20 MPG to as low as 11 MPG while it’s in regen.
The first time it happened to me it was alarming. I had 500 on the odometer and I was stopped at a light after pulling off the interstate. It was a very strong smell like burning brakes or burning coffee.
As time one goes on the regen smell is not as strong.
Old Mar 31, 2019 | 09:05 AM
Redrockerstl55's Avatar
Redrockerstl55
You can activate the “percent full” showing how close you are to a regen via FORScan. When the filter starts to empty you are in a regen.
Old Mar 31, 2019 | 11:01 AM
cficare's Avatar
cficare
You may also get your dealer to activate the DPF% screen using their IDS system. When I did, they were not aware it could be enabled, but they now offer it to others for a nominal fee.
Here is the thread with the IDS screen shots ...
https://www.ford-trucks.com/forums/1...on-2017-a.html
Old Apr 9, 2019 | 08:51 PM
HKEadventures
Thanks everyone. I’m sure it was a regen. Haven’t smelt it since. And that smell was right at 500 miles. Just passed 1000 a few days ago
red2002FX4
2009 - 2014 F150
Feb 11, 2014 01:25 PM
Tim Young
6.7L Power Stroke Diesel
Nov 10, 2013 01:28 PM
RangerEdgeO2
6.4L Power Stroke Diesel
Feb 2, 2008 11:23 AM
RickyD
May 3, 2005 07:02 AM
