Wrench light randomly comes on 2010 escape
Old 03-30-2019, 06:20 AM
Austin Collins's Avatar
Austin Collins
Austin Collins is offline
My girlfriend has a 2010 v6 escape XLT with less that 15,0000 miles. A few months ago (winter time) is when this light first appeared just after starting it. The idle was real heavy, but if I turn off the car and back on, it doesn't pop up. A few months passed of no sign of this light or any performance problems, untill I was driving and the light turned on.
(This was a first cause normally it only came on in cold start ups.) I proceeded ro drive and I gently pushed the throttle just to get up a couple MPH to speed limit, and the RPM went from a steady 17-18...and quickly jumped to 3000, roughly shifted, and went right back down. I pulled over at that point and found out my transmission fluid was almost empty. I may have accidently put too much in, but the wrench went off, performance was normal, but my emgine light is still on. Any ideas on what things to check out to fix this random problem ould be appreciated.
ALSO...if you over fill your transmission, is it harmful? Or could I keep driving it? Thanks!
This is my first time writing a forum, so any help or ideas would be amazing! Thanks.
Old 03-30-2019, 08:19 AM
seville009's Avatar
seville009
seville009 is offline
Stop by an auto store and have them check for codes; that will tell you what problems may exist.
Should not overfill any of the fluids; need to drain some of the transmission fluid out if it’s overfilled
matts156
07-25-2014 02:16 PM
Pool Runner
2009 - 2014 F150
20
11-27-2013 04:33 PM
fordpride
Escape & Escape Hybrid
10-21-2012 07:45 AM
FuzzEMoto
03-06-2012 12:56 PM
gbpfan
07-03-2004 05:17 PM
Quick Reply: Wrench light randomly comes on 2010 escape
