Truck shocks
Old Mar 28, 2019 | 03:30 PM
drdit92's Avatar
drdit92
Truck shocks
I'm preparing to head to Alaska for 3 months at the end of May. My fiver weighs around 11k last time I weighed it, but I'll probably be up around 12k for this trip. I'll be driving just over 10,000 miles in total. My tow vehicle is a '17F350 SRW CCLB 6.7L PS. It's completely stock. Are there any recommendations for shocks? I don't have any chocking with my hitch (Andersen Ultimate) but towing and not towing sometimes those bumps in the road don't feel too good--though I will say my 350 is way more comfortable than my old gas 250 shortbed. Just trying to make sure I have a great experience on this long trip. Would welcome any other advice/recommendations beyond the shocks if you have something. Thanks.
Old Mar 28, 2019 | 06:29 PM
slapshot12's Avatar
slapshot12
I’m looking to replace my shocks too, stock Ford Rancho’s, and have narrowed it down to Bilstein 5100 or Rancho 9000’s. I’m still trying to compare them and see which is better. I read many places that Fox’s will likely be too soft for towing.
I also added some Timbren springs and they help a lot with the bumpy and uneven roads.
Old Mar 29, 2019 | 07:51 AM
wrvond's Avatar
wrvond
As rough as the Alaska Highway is, this is one time I'd think about shocks with an external reservoir.
Otherwise I'd look at shocks with the largest diameter tubes, the largest diameter piston shafts, and the most oil.
I've come to the conclusion that there is no way some guy that doesn't know my particular driving conditions can design and valve a shock to fit my needs. For this reason I like the adjustable Rancho 9000 shocks. Through trial and error I have determined the settings that give me the ride I want. Their build is also much more robust than the OEM shocks they replaced.
Old Mar 29, 2019 | 09:56 AM
Clubwagon's Avatar
Clubwagon
+1 on the Bilsteins or Rancho 9000s.
Old Mar 29, 2019 | 01:44 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
I've been pulling trailers for a long time and I'm sold on good old fashion Monroe Gas Magnums, I have then on my truck and trailer, I also had them on my last truck when we did Alaska and was glad we had something that stiff and fast acting when going over the frost heaves and at times very rough roads.
Take your time and enjoy the trip in Alaska and Canada, the roads aren't that bad if you take it slow.
Denny
Old Mar 29, 2019 | 09:15 PM
HRTKD's Avatar
HRTKD
One thing I don't understand about the trailer shocks is why they provide damping in only one direction. I thought my trailer shocks were shot because of that so I bought four new ones. Same one-way damping with the new ones.
If I knew how to find real shocks to fit, instead of "RV Shocks" I would do it.
Old Mar 29, 2019 | 09:21 PM
rvpuller's Avatar
rvpuller
I went to Shock Warehouse and crossed the number on my original ones.
Denny
Old Mar 29, 2019 | 09:33 PM
HRTKD's Avatar
HRTKD
Denny
I could be wrong but I think mine were the same part number as the old ones.
Old Apr 10, 2019 | 01:22 AM
stufarmer's Avatar
stufarmer
I'm running the Rancho 9000's. Have to say, running empty the ride is so much better over the O.E. Rancho's ..
Old Apr 10, 2019 | 11:27 AM
stufarmer's Avatar
stufarmer
Maybe you could try putting them on upside down .. LOL !!!
Old Apr 10, 2019 | 11:43 AM
HRTKD's Avatar
HRTKD
That would work. The way they attach is the same top and bottom. But I know you're being facetious. To take that one step further, I could set up a double shock bracket and install one shock right side up and the other upside down.
If I was willing to throw good money after bad I would spec out a set of regular car/truck shocks instead of using trailer shocks.
Old Apr 17, 2019 | 06:20 PM
slapshot12's Avatar
slapshot12
I ended up ordering Bilstein 5100’s and a Fox steering stabilizer. The steering stabilizer makes a noticeable difference, and I’m hoping the shocks will too once I get them.
Old Nov 9, 2021 | 01:03 PM
speakerfritz's Avatar
speakerfritz
you did say "best"
king shocks would be the best
2nd best, fox 2.5
the fox 2,5 would cost about 1200 for a rear pair.
Old Nov 9, 2021 | 02:40 PM
Big Mak's Avatar
Big Mak
I've owned both Bilstein and Rancho 9000s. I prefer the Bilsteins over the Ranchos.
Old Nov 10, 2021 | 08:00 AM
pjones1969's Avatar
pjones1969
I swapped out the factory Ranchos at 72000 miles for KYB MonoMax and wasn't impressed, swapped out the KYBs for Fox 2.0 at 110000 and notice a huge improvement
