The Never-Ending (slow-cranking) Story of my 6.9
Our 6.9 cranks slowly. I've done a lot to improve it. But it still cranks not as well as I'd like it to, or as well as our 7.3 does.
Here are voltage readings this morning, 58F cold start.
I also suspect that the PO should have used thicker gauge wire for the starter lead. It must carry the current from both batteries to the starter. I'm thinking of making up a thicker cable.
What are your thoughts?
- New batteries
- New gear-reduction starter (this made an improvement)
- New battery cables (done by PO)
- New voltage regulator
- Battery terminals cleaned and coated with copper conductive lube
- 12.6v before turning the key
- 11.6v when the glow plugs kick on before starting
- 12.0v to 12.8v after startup, with glow plugs still cycling
- 14.3v at idle after a minute
- 14.6v at 1200 rpm
on
You can rule out the alt (that should get a 3g alt upgrade anyway though.There's no reason any IDI engine on the road doesn't have this affordable swap done by now really) by just charging the batteries overnight with a charger.If it then turns over super fast,then there ya go.
Do you know what size cables those are? Factory was 2/0 between bats and 3/0 down to starter but 2/0 overall is ok and is what the latter IDI's all got.
Yep, the cables are too small, and more importantly there looks to be a ring connector at the cable to the battery side to the starter lead.
That's the big choke point, cable going straight to the post clamp like as is going to the spare battery, and bigger cable - is the fix.
If you need to, use a ring connector to the second battery instead of the lead to the starter as the PO had done.
That ring connector could just be it. I need a double ended post, don't I.
By 3g do y'all mean 1-wire alternator, with integrated voltage regulator?
I should have been more complete in the initial post. All connections are clean, dabbed with copper conductive, and tight.
I'm telling you, the 3G alternator swap is the way to go. They're rated at 130 A for the 94 Taurus.
https://www.rockauto.com/en/catalog/...generator,2412
C'mon man. Evreybodys doin' it!
You may be able to score a leece neville ambulance alternator off of an ambulance at a junkyard. There just shy of 200 amps
The ring terminal has nothing to do with it, I don't even understand why someone brought that up. If they are talking about the smaller wire, its on the outside of the bolt from what I can tell, which is fine.
The bigger issue as stated is the small battery cables. Upgrade those and you'll be fine. O'reillys stocks one for about $80 if you have one near by. Other options include making them up from decent cable locally, with the proper size terminals. A ring terminal properly sized to the cable and bolt used is absolutely fine, and how most big rigs have their batteries connected.
Think of it this way, your battery is like a big water tank, the battery cables are hoses hooked off the tank, and the alternator is the pump that fills the tank. No matter how big a pump (alternator) you hook up to your tank to keep it full of water (charged up) if you only have a normal garden hose, you're not going to get the volume/pressure of water a firehose would provide. Our IDI starters need a firehose to spin quickly. Anything smaller than 2/0 is restricting your starter, and slowly killing it by not providing sufficient current, which will cause a voltage drop.
Here's a quick way to test this, you say your other truck cranks faster, swap the cables over and see what happens.
SNIP
SNIP
I wound up with RockAuto for $66 including shipping. I try not to use them much anymore since they went to bot-based customer service. But this time I really want that cable. Fat, molded, OEM quality, split-loom already in place. Some guys like ****, I like auto parts.
I'll post again once we install it. And start looking for an ambulance alternator.
