5er Tires
Old Mar 27, 2019 | 04:42 PM
Tugboatguy's Avatar
Tugboatguy
5er Tires
I'm looking at buying a 2017 Crusader 5er. The tires are TOW MAX STR ST235/80R16 load range E. I'm trying to determine when they were built. I found the following on the sidewall DOT ADB5 TBST 4615. Does that have info I'm looking for? If so, how do I decipher that info?
Thanks.
Old Mar 27, 2019 | 05:11 PM
Clubwagon's Avatar
Clubwagon
Assuming that is the tire's date code it was built the 46th week of 2015.
I went out and took this photo of the date code marking on my trailer tires. As per the date code mine were manufactured the 24th week of 2017. I would assume a 4 year old tire to be nearing the end of its service life.
Old Mar 28, 2019 | 06:18 PM
Tom N OH's Avatar
Tom N OH
Clubwagon is correct. 46th week of 2015. Tow Maxes are known as Blow Maxes on the RV forums. Definitely think about replacing them. Sailun S637 are a much better tire with a great reputation at a very reasonable price point.
Old Mar 28, 2019 | 07:50 PM
Tugboatguy's Avatar
Tugboatguy
5er tires
Thanks for the replies. Gives me something else to research. I’m leaning towards Sailun or GY Endurance. Still researching LT tires, but I’m just not sure what makes the most sense.
Old Mar 29, 2019 | 09:55 AM
RA12726's Avatar
RA12726
Banned
X2^^. Stick with ST rather than LT tires on the fiver. The sidewalls are very different.
Rob
Old Mar 29, 2019 | 10:31 AM
acadianbob's Avatar
acadianbob
Well, that statement will probably ignite a *****storm among the LT tire crowd. But, I agree with you.
I'd say to look for a tire with a good speed rating. Some are rated for 75 or 81 mph. I like the Carlyle tire.
You'll probably also get a load of "China Bomb" comments. I've towed with so called China Bombs for 15 years and 10's of thousands of miles with nary a single problem. This includes all day tows in 95 degree heat and nasty rock strewn national forest service roads.
Buy adequate load capacity, keep tires fully inflated, get a tire pressure monitoring system, watch your speed, balance your load, avoid road hazards and curbs. You'll be fine.
Old Mar 31, 2019 | 09:27 AM
senix's Avatar
senix
To the best of my knowledge, Goodyear Edurance is the only USA made ST tire. That is what I am running.
LT's are fine as well.
I would not buy the trailer with those old china bombs, either they give you a credit or they replace with correct, safe tires.
If you buy with them on it, Then a trip home, not too fast and then swap them out before going anywhere.
Old Mar 31, 2019 | 12:59 PM
ssunit1's Avatar
ssunit1
Got rid of the original China Bombs soon after getting my 5er. Put on a set of GY Endurance almost 3 yrs and 12k miles ago. Watched the pressure and got a TPMS. Seem to be wearing well and no issues thus far.
Old Apr 1, 2019 | 12:03 PM
ATC_F350's Avatar
ATC_F350
I glad you did so well with your China Bombs, If they last 3 years with my trailers, I'm happy. I own 9 trailers, the only ones without problems are one converted to 17.5 trailer tires, one with LT tires, and one with some Gladiator Chinese tires. The Gladiators get good reviews and seem almost a semi-truck type construction, but have a bounce between 30-40 mph on the 14k dump trailer.
Old Apr 1, 2019 | 06:20 PM
senix's Avatar
senix
I had Gladiators, they blow too.
Old Apr 1, 2019 | 06:23 PM
ATC_F350's Avatar
ATC_F350
I guess 17.5's or LT's are the ticket.
Old Apr 1, 2019 | 11:02 PM
KRSCHWEIZ's Avatar
KRSCHWEIZ
Goodyear G614 are a load range G rated tire, with a mph range around 80 mph. I don't tow that fast but some might like to. These tires are also able to be regrooved. 110 psi max. made in USA. They are pricey and are used on the larger fifth wheels and toy haulers.
Sailun is also a G rated tire with many similar qualities as the Goodyear. They do not cost as much as the G614. Not sure if they are made in the USA.
Old Apr 2, 2019 | 11:55 AM
WE3ZS's Avatar
WE3ZS
I too run the Sailun ST tires, they are an excellent tire that is made in an ISO compliant factory in China, not all Chinese ST tire's are bombs, just most.
I lost 7 China Bomb ST tires over a few year period and about 20K miles of towing, not a single one lost a pound of air, all suffered some degree of tread separation. All of my tire's get their pressure checked prior to a trip, are covered when parked at home, they are not driven off road and I use a TPMS. I don't trust and will no longer use CHEAP Chinese ST tires.
Old Apr 2, 2019 | 07:01 PM
brickman's Avatar
brickman
I’m running Bridgestone Duravis r500 hd’s on our Fiver. Got about 45,000 km’s on them since 2017, fantastic tire very strong , never had any issues apart from picking up a screw once. They are showing very little sign of any wear. & Not made in China...
abe
May 26, 2013 07:34 AM
truckdog62563
30
Dec 31, 2010 06:18 PM
JoeKan
Jul 1, 2009 10:14 AM
Buck123
Aftermarket Products
Jun 7, 2009 12:55 AM
cajunbull61
Aug 7, 2007 04:17 PM
