Brake torque specs
Old Mar 26, 2019 | 02:39 AM
3Prcntr's Avatar
3Prcntr
Brake torque specs
2006 XLT 4x4. Doing brakes on my truck and getting some mixed info. I don't have a repair manual so I am relying on the internet, but there are tons of confusing posts, even some posts on the same threads that say different specs and I want to get the correct ones.
I am replacing calipers (& pads) as well as rotors. So if spec for front and rear differ, please specify.
I need the torque specs for the following:
1. Flow bolt (not sure if that is even what it's called) on the brake line that holds the two washers.
2. Caliper anchor (bracket) bolts. The rear are attached to the axle, but I assume they are the same spec as the front.
3. Caliper bolts.
What I have is:
26 for the flow bolt
148 for the anchors
47 front caliper
22 rear caliper
Are these numbers correct?
Old Mar 26, 2019 | 11:33 AM
Rumble phish's Avatar
Rumble phish
If you're getting differing specs on the Internet, I would suggest you fork out the $29.99 for a Haynes or Chilton's manual at your local auto parts store. Not trying to be a jerk, but I've learned the hard way
Old Mar 26, 2019 | 10:01 PM
Shadow351's Avatar
Shadow351
We always called the bolt that holds the line to the caliper a "banjo bolt".
Those values seem to match the ones in the manual for my 2004
Old Mar 27, 2019 | 10:16 PM
3Prcntr's Avatar
3Prcntr
Brakes done!
ronjohn
Sep 8, 2012 09:04 AM
Texas Outlaw
Feb 13, 2008 01:17 PM
bhestand
Jun 6, 2005 07:49 PM
