LED Conversion
Old Mar 25, 2019 | 09:28 PM
TXTrailerdaddy's Avatar
TXTrailerdaddy
LED Conversion
So as I'm restoring this truck I decided while I'm putting in the brand new AAW harness, I may as well go to LED lights. I went to superbrightled.com and went through and ordered my LED's. Seemed easy enough. Got them in 2 days. cost about $108 for everything, but my cargo light( cause I forgot about it) and headlights. Not terrible, I guess. I should mention I am putting in a Dakota Digital dash so there are no bulbs needed for the gauges, at least not for me. Seemed really easy, but I had my doubts for LED lights for a few spots because of the size of the bulb. The bulb for the headlight/wiper switch and the ashtray mainly. The LED bulb is to large to fit into the tube, so my doubts were confirmed. I couldn't get the glove box light to work either.... but it was late, and I was tired. I'll take another crack at that one, I can probably get that one going. The one in the temperature controls was easy, and it's like the replacement bulbs for the guages if you have stock ones. Not too bad overall, but I'm disappointed I cant put LED's on those other two. Guess I'll get some new incandescent for those.
Old Mar 26, 2019 | 01:10 AM
Ozzie H.'s Avatar
Ozzie H.
Shop around. LEDs come in many different dimensions.
Old Mar 27, 2019 | 09:22 PM
TXTrailerdaddy
Anyone know if I need to put resistors on all 4 turn signal bulbs or just one per side.
Old Mar 28, 2019 | 02:07 AM
84espy's Avatar
84espy
You will need a flasher compatible with LED lights.
Old Mar 28, 2019 | 07:39 AM
TXTrailerdaddy
From what I've read, it's an either/or thing. If I get the LED flasher, then I don't need resistors. But, when I bought the LED's none of the flashers that were offered at superbrightled.com would fit, because they are square and the aftermarket fusebox that I have has recessed round flasher sockets. I have seen summit and a few other places with the proper flasher, but I bought 1 pack of resistors because I thought I had read that if you had a resistor or one incandescent per side it would work. I'm just trying to confirm that.
Old Mar 28, 2019 | 09:49 AM
resonateur's Avatar
resonateur
...easier just to change to an electronic flasher. Just mount it, but not in the round clip. There are LED bulbs with the same base that you need, but smaller elements. Just measure the incandescent and look at the size specs of the led. You should be able to find one to fit. For things like the headlight and wiper switch indicators, you can use an led with a clear acrylic element, sand and polish the end of that to get the angle that you want the light to emit.
Old Mar 28, 2019 | 12:33 PM
EQCMCAT's Avatar
EQCMCAT
TXTrailerdaddy,
I haven't had luck getting a combination of all LED turn signal bulbs with an electronic flasher to work in my 77 F-150, so I went back to all incandescent front and rear 1157 turn signal bulbs. With all LED turn signal bulbs installed and with either the electronic or original turn signal flasher, my turn signals would not flash. With just one LED and incandescent installed either front or back turn signal and either electronic or original flasher installed, my turn signals flashed too rapid. I gave hope and went back to all original 1157 incandescent turn signal bulbs.
I do have LED bulbs installed in the instrument cluster, dome and under dash courtesy lights, and like them.
Old Mar 28, 2019 | 10:03 PM
TXTrailerdaddy
Ok... I figured it out. If there is one incandescent per side, it will work. But, since I want all LED I put one resistor on the front turn signal wires and they work like a charm.
Old Mar 29, 2019 | 09:12 AM
niko20's Avatar
niko20
What is the value and wattage of the resistor, for future reference?
Old Mar 29, 2019 | 10:31 AM
TXTrailerdaddy
Hey Niko, I just bought an LED resistor kit from superbrightled.com. You get 2 resistors for $5. If by value you are asking why I use it, without it the LED bulb will either not come on, or not flash. The resistance creates the heat necessary in the flasher to trigger the relay so you get it to flash. The electronic flashers don't need that so they work whether or not you have LED or incandescent. Problem is those cost $10-$22 a piece and you have 2 of them. 1 for turn signal 1 for hazards. So $5 for resistors is cheap compared to $20 - $45.
Old Mar 29, 2019 | 10:52 AM
fordguy2100's Avatar
fordguy2100
He's asking what's the ohms on the resistor.
Old Mar 29, 2019 | 01:06 PM
TXTrailerdaddy
resistor says 50watt and you need 1 per bulb but it’s working just fine 1 per side.
Old Mar 29, 2019 | 01:11 PM
TXTrailerdaddy
Old Mar 29, 2019 | 01:14 PM
fordguy2100
Niko quick google search shows that resistor to be 6ohms FYI
Old Mar 29, 2019 | 11:25 PM
azroxx's Avatar
azroxx
I was talking about those vampire clips today with my buddy. How can you make them waterproof? Or do I even need to worry about that? For under hood installs I would like waterproof I think, but maybe not an issue?
