1951 239 flahead
Old Mar 25, 2019 | 07:23 PM
ynot321AB1's Avatar
ynot321AB1
1951 239 flahead
I have this engine I put into a 1950 F-1, I am trying to figure out if the motor is positive ground. The coil has a battery side and a distributor side, there is wire from the marked battery side of the coil going to the distributor thereby giving me the impression I have a positive ground. Any help I could get in finding out would be greatly appreciated .
Old Mar 25, 2019 | 07:29 PM
raytasch's Avatar
raytasch
Believe Nothing
The truck was originally six volt positive ground. It will run either way.
Old Mar 25, 2019 | 07:37 PM
ynot321AB1's Avatar
ynot321AB1
Thanks
You mean it will not burn up like the solonoid and the voltage regulator if I run it as a negative ground?
Old Mar 25, 2019 | 08:06 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Regardless of whether the truck is (+) or (-) ground, the BAT side of the coil should go to the ignition switch, not the distributor.
Steves55
Apr 13, 2017 10:48 PM
Jeff K
31
Oct 21, 2013 02:49 PM
73 ford guy
Dec 2, 2010 07:51 AM
1972-34ton
Jul 27, 2009 10:47 PM
KEITHS 1950 F68
Jun 6, 2004 03:43 PM
