Sponsored by: Real Truck
Transfer case lube?
Old Mar 26, 2019 | 10:58 PM
Claluja's Avatar
Claluja
Originally Posted by Qwazert
It's not a question of not wanting to use it...I went to my local dealer and asked for it by name.
Parts person told me they no longer stock it because it was superseded by Ford.
Here are some dealers discussing it
https://www.ar15.com/forums/General/...=bottom#bottom
Use XL-12 if you can get it, online or wherever. If not, Mercon LV.
Note: I think the guy in your video says not to use Mercon (different than Mercon LV).
Old Mar 26, 2019 | 11:20 PM
Qwazert's Avatar
Qwazert
Yes....listening to it again, he specifically states to NOT use Mercon V in the transfer case. I just assumed that Mercon V and LV were the same stuff....my bad!
According to your link, the spec sheet for the Mercon LV https://www.fcsdchemicalsandlubrican...ission%20Fluid
says that it can indeed be used "in all transfer cases".
Looks like I know what to get now....thank you everyone!
Old Mar 27, 2019 | 07:30 AM
don123's Avatar
don123
I used xl-12 as stated in my manual when I changed mine. You can get it on amazon.
Old Mar 27, 2019 | 08:28 AM
saratoga2011's Avatar
saratoga2011
Originally Posted by 00t444e
Yes, the chain driven NV series transfer cases have always used Mercon( Ford spec), Dextron (GM spec), or atf 4 (Chrysler) since they came out they aren't real picky about fluid so each manufacturer always listed their own ATF spec to use in them, since they have all used NV series t-cases at some point. Then all of a sudden one video comes out about a transfer case exploded and dedicated transfer case fluid is needed to prevent this. Yet the video offers little detail on how the fluid it was using caused a failure or what the failure point was. So after over 20 years of using ATF in these transfer cases with no problems, now everyone thinks you have to use the transfer case fluid, it's nothing more than a scam in my opinion.
Yup. It's basically the same transfer case used in all 3. In reality, any cheap multi-vehicle ATF will be fine. In the F250s I've had, I have used M-1 synthetic ATF and supra tech ATF. In the 2500HD I had, I used Dex 3, Allison TranSynd, and even 5W30 engine oil for a while back when that was all the rage and the GM transfer cases had the "pump rub" issue.
There's nothing magical going on inside. There's a small pump that keeps the bearing in the output shaft lubed while you're in 2wd, that's all. That's also the reason the xfer case fluid should be changed regularly even if you rarely use 4x4.
Old Mar 27, 2019 | 11:16 AM
Qwazert's Avatar
Qwazert
OK...a phone call to my local Dealer and this is what I got:
XL-12 has been discontinued and superseded by the Mercon LV...so LV is what they use in the transfer cases now.
So that is what I'll be using, although probably NOT the Motorcraft stuff........probably some off-the-shelf type with the LV spec.
Old Mar 28, 2019 | 12:54 PM
2004 F450's Avatar
2004 F450
My early 2004 F450 manual says to use Mercon in the transfer case. Assume I can use either Mercon or Mercon LV.?
Skauber
18
Apr 2, 2017 07:45 AM
epoppe4
Apr 29, 2016 03:45 AM
mr.noodi
Jul 30, 2015 06:19 PM
tbenks
Dec 28, 2009 07:31 PM
B1GKAHUNA
Mar 25, 2007 10:27 AM
